Go to Post Seriously, when I grow up (or if I grow up) I want to be just like Al. - Paul Copioli [more]
Unread 05-01-2014, 16:13
Izzy Izzy is offline
FRC #0418
Izzy is an unknown quantity at this point
General Possession Rule Clarification
POSSESS: (for a ROBOT) to carry (move while supporting BALLS in or on the ROBOT), herd (repeated pushing or bumping), launch (impel BALLS to a desired location or direction), or trap (overt isolation or holding one or more BALLS against a FIELD element or ROBOT in an attempt to shield them) a BALL.
ROBOT: an electromechanical assembly built by an FRC Team to perform specific tasks when competing in AERIAL ASSIST. It includes all of the basic systems required to be an active participant in the game: power, communications, control, mobility, and actuation. The implementation must obviously follow a design approach intended to play AERIAL ASSIST (e.g. a box of unassembled parts placed on the FIELD or a ROBOT designed to play a different game would not satisfy this definition).
Does "launch" imply ROBOT initialization of motion requiring that it had physically touched our ROBOT's actuator/manipulator assembly?
Unread 05-01-2014, 16:17
donkehote's Avatar
donkehote donkehote is offline
Design/Manufacture/Strategy Mentor
AKA: Kevin
FRC #5031
donkehote is just really nicedonkehote is just really nicedonkehote is just really nicedonkehote is just really nice
Re: General Possession Rule Clarification
I read it as you posses the ball if you make multiple contacts. herding can be done with bumpers, so i dont think that you need it to touch an actuator/manipulator. Think of the rookies if that was the case!
Emphasis mine
Unread 05-01-2014, 16:20
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
If you could find some way to move a ball without touching it (A fan or 'the force') you would still be impelling momentum on the ball and possessing it.
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
Unread 05-01-2014, 16:21
FRC #0418
I edited my post to clarify, what I was actually referring to, my apologies.
Unread 05-01-2014, 16:30
donkehote's Avatar
AKA: Kevin
FRC #5031
I get it now. hmmm... seems like a good question for Q&A
Unread 05-01-2014, 16:32
FRC #0418
Are you positive, for that would give rise to the question of whether the air (or some psychic energy) is part of the ROBOT [refer to definition] (which it is not, nor of the manipulator system). Someone asked about suction (vacuum), but it would not be possessed until it docks the robot's vacuum manipulator, correct? Much like static suction (i.e. plunger). You could place distance suction under the same definition as "launch," and I don't think that the field or referees will grant possession for an assist until the robot has made contact with the ball.
Last edited by Izzy : 05-01-2014 at 17:00. Reason: for reference and clarification
Unread 05-01-2014, 17:56
RPI 2018
AKA: Joe Iaquinto
Any sort of remote force fits the definition of launch per the POSSESS definition. The point at which your robot deliberately affects the momentum of the ball is the point at which you are considered to possess the ball.
