Re: Not doing autonmous
much thanks!!! next thought. . . use our balls as a defensive mechanicms to push their balls
G12 An ALLIANCE may not POSSESS their opponent’s BALLS. The following criteria define POSSESSION : “carrying” (moving while supporting BALLS in or on the ROBOT), “herding” (repeated pushing or bumping), “launching” (impelling BALLS to a desired location or direction), and “trapping” (overt isolation or holding one or more BALLS against a FIELD element or ROBOT in an attempt to shield them). Violation: TECHNICAL FOUL per instance. I would consider that herding and it may result in you causing great harm to your alliance's scores. |
By this do you mean firing your ball at the other alliance in auto to somehow disrupt their shots? Huh...didn't think of that.
I suggest the following website: http://frc-manual.usfirst.org/
. It will be your friend. Look here often for team updates in the following days and weeks.The FRC Q&A site is the single source for official answers from the Game Design Committee (GDC). |
I will throw this out there. There is a scenario where skipping autonomous to go for the 3 assist may be advantageous and legal.
http://www.patriots.com/media-center...b-d3dbf0d16209 |
Also in reply to the original question on using the ball defensively, I think you might be breaking this rule: Quote:
#7
Using the ball herd your opponents ball seems to fall under herding. Of course, you should try to herd a ball with a ball before deciding on this strategy. Keep in mind that contact that isn't herding (like a robot form of a slide tackle) appears to be perfectly legal as the rules appear today. |
#8
I have also pondered throwing the ball at other robots during autonomous. It could deal some potential damage to their scores, and appears perfectly legal as far as I've seen.
#9
G27 is a Robot-Robot interaction rule. A ball is not a robot.
#11
We are not going to do that. While it is a valid strategy, I think it would be a stupid decision to waste the autonomous points to potentially stop someone else from scoring, especially when we can just make sure that our points cancel theirs (getting as many in autonomous as possible).
And Jee7, I was not saying tipping bots by launching balls at them, I meant shooting the balls to change their positioning on the field. I also did not mean to damage them, but to damage or hurt their scores. It was poorly worded. My fault. |
#12
You are certainly entering a gray area. While that rule is listed under robot-robot interactions, where does that say that the strategy involves robot-robot contact?
To simplify the statement: A strategy aimed at inhibition of a robot via damage of a robot is not allowed. The rule talks about the "Strategy" not "Contact". If you go out onto the field match after match and plunk the robot behind you with the ball, I think it's safe to say the referees would take issue with that. But hey, if you want to roll those dice, that's up to you. |
#13
The vast majority of the threads that I've seen on CD since kickoff (including this one) are answered directly in the manual. Both of the OP's first two questions could be answered by reading the manual more carefully. It appears that the OP's first language is not english though so I can imagine that understanding the technicalities of a rulebook not written in their native language is probably pretty difficult. |
