Go to Post Mentor-built (adj.): A term describing a robot that is better than your own, and / or a robot with paint on it. - Chris is me [more]
Unread 05-01-2014, 16:24
alextound alextound is offline
alextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these partsalextound is infamous around these parts
Wink Not doing autonmous
Could not doing autonomous to get a triple assist and get in the high goal . . . rather than an autonmous lower goal. . . please calculate . Also, would it be legal cause how does the scoreboard (lights) recognize 2 even 3 different assist build-ups???
Unread 05-01-2014, 16:29
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Not doing autonmous
You cannot get a assist from an autonomous ball because a cycle starts only after a ball from the pedestal is put into play
A CYCLE is the series of events that recur regularly, and each CYCLE begins with an ALLIANCE member retrieving their BALL from their lit PEDESTAL and ends when the BALL is SCORED in a GOAL. Major events in a CYCLE are depicted in Figure 3-1.
ASSISTS are earned when a unique ALLIANCE ROBOT POSSESSES the ALLIANCE’S BALL in a unique ZONE (i.e. red, white, or blue ZONE) during a CYCLE. A ROBOT is considered in a ZONE if it is in contact with the carpet in a ZONE or the tape marking the ZONE, but not in contact with carpet or tape for another ZONE. Because there are up to three (3) ALLIANCE ROBOTS and three (3) ZONES, the maximum number of ASSISTS in a single CYCLE is three (3). Examples of the number of ASSISTS credited to an ALLIANCE are shown in Figure 3-4 (X = POSSESSION, yellow highlight = credited ASSIST, ROBOT IDs are across the top, ZONES are depicted by color).
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 05-01-2014, 16:30
much thanks!!! next thought. . . use our balls as a defensive mechanicms to push their balls
Unread 05-01-2014, 16:31
alectronic alectronic is offline
no team (Volunteer)
alectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant future
Could you please rephrase and post again? Your post doesn't seem to be clear. Thanks.
Unread 05-01-2014, 16:35
donkehote's Avatar
donkehote donkehote is offline
Design/Manufacture/Strategy Mentor
AKA: Kevin
FRC #5031
donkehote is just really nicedonkehote is just really nicedonkehote is just really nicedonkehote is just really nice
3.14 scoring discusses this
Points are awarded once per CYCLE for BALLS SCORED by ROBOTS in the GOALS, BALLS SCORED by ROBOTS
over the TRUSS, and for each ROBOT CATCH. Additional points are credited to an ALLIANCE upon each GOAL
based on the number of ASSISTS earned by the ALLIANCE for that CYCLE.
the balls in auto arent part of a cycle. they diddnt start on the pedestal, so there can be no assists, or truss or catch bonus applied to them
image is all weird, gonna try to fix.
there much better.
Unread 07-01-2014, 13:49
ethen155's Avatar
ethen155 ethen155 is offline
AKA: Ethan
FRC #1831 (Screaming Eagles)
ethen155 is an unknown quantity at this point
Unhappy Re: Not doing autonmous
The rules about touching the other teams balls are very dangerous.
G12
An ALLIANCE may not POSSESS their opponent’s BALLS. The following criteria define POSSESSION :
“carrying” (moving while supporting BALLS in or on the ROBOT),
“herding” (repeated pushing or bumping),
“launching” (impelling BALLS to a desired location or direction), and
“trapping” (overt isolation or holding one or more BALLS against a FIELD element or ROBOT in an attempt to shield them).
Violation: TECHNICAL FOUL per instance.
I would consider that herding and it may result in you causing great harm to your alliance's scores.
Unread 07-01-2014, 13:53
JohnFogarty's Avatar
AKA: @doctorfogarty
By this do you mean firing your ball at the other alliance in auto to somehow disrupt their shots? Huh...didn't think of that.
John Fogarty
Unread 07-01-2014, 13:59
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
I suggest the following website: http://frc-manual.usfirst.org/ . It will be your friend. Look here often for team updates in the following days and weeks.
The FRC Q&A site is the single source for official answers from the Game Design Committee (GDC).
Unread 07-01-2014, 14:15
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
I will throw this out there. There is a scenario where skipping autonomous to go for the 3 assist may be advantageous and legal.
http://www.patriots.com/media-center...b-d3dbf0d16209
mbshark's Avatar
mbshark mbshark is offline
AKA: Myles Byrne
FRC #3932 (The Dirty Mechanics)
mbshark is an unknown quantity at this point
Most people posting in CD have already looked in the rules and could not find it themselves - that is why they post it here.
Also in reply to the original question on using the ball defensively, I think you might be breaking this rule:
3.2.6.2 G28
Deliberate or damaging contact with an opponent ROBOT on or inside its FRAME PERIMETER is not allowed.
For example, use of wedge-like MECHANISM to flip ROBOTS would be considered a violation of G27.
High speed accidental collisions may occur during the MATCH and are expected. ROBOTS extend elements outside of the FRAME PERIMETER at their own risk; no penalties will be assigned for contact between two such extended elements.
A ROBOT with an element outside its FRAME PERIMETER may be penalized under this rule if it appears they are using that element to purposefully contact another ROBOT inside its FRAME PERIMETER. Regardless of intent, a ROBOT with an element outside its FRAME PERIMETER that causes damage to another ROBOT inside of its FRAME PERIMETER will be penalized.
Unread 07-01-2014, 15:08
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Nah...using the BALL wouldn't be a G28 violation as the BALL isn't an element of the ROBOT.
Using the ball herd your opponents ball seems to fall under herding. Of course, you should try to herd a ball with a ball before deciding on this strategy. Keep in mind that contact that isn't herding (like a robot form of a slide tackle) appears to be perfectly legal as the rules appear today.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 07-01-2014, 15:17
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
I have also pondered throwing the ball at other robots during autonomous. It could deal some potential damage to their scores, and appears perfectly legal as far as I've seen.
Unread 07-01-2014, 15:23
FRC #6357
There you are potentially running afoul of G27:
G27
Strategies aimed at the destruction or inhibition of ROBOTS via attachment, damage, tipping, or entanglement of ROBOTS are not allowed.
Violation: TECHNICAL FOUL and YELLOW CARD
FLL Mentor 2006
FRC 619 Mentor 2002
Unread 07-01-2014, 15:36
Originally Posted by jee7s View Post
G27
Violation: TECHNICAL FOUL and YELLOW CARD:
G27 is a Robot-Robot interaction rule. A ball is not a robot.
Unread 07-01-2014, 15:50
We are not going to do that. While it is a valid strategy, I think it would be a stupid decision to waste the autonomous points to potentially stop someone else from scoring, especially when we can just make sure that our points cancel theirs (getting as many in autonomous as possible).
And Jee7, I was not saying tipping bots by launching balls at them, I meant shooting the balls to change their positioning on the field. I also did not mean to damage them, but to damage or hurt their scores. It was poorly worded. My fault.
