Go to Post Now I'm off to see the wizard, the wonderful wizard of Cogs. - Matt Krass [more]
Unread 05-01-2014, 13:08
mechlectrician7's Avatar
mechlectrician7 mechlectrician7 is offline
FRC #0894 (Powers 894)
Team Role: Electrical
mechlectrician7 is an unknown quantity at this point
missed shots
The manual did not cover what is to become of any balls that may miss the intended goal durring auton. Do they become free to pick up and attempt to score with again, but without assist or trust bonuses? Also i do not remember seeing anything about if after a ball is at the end of its cycle, about to be thrown, or scored with somehow (say with 3 assist points) if the shot is missed. Can it be picked up and shot again without loss of bonuses? Any information will be helpful and appreciated
Unread 05-01-2014, 13:19
DonRotolo's Avatar
Back to humble
FRC #0832
Re: missed shots
Yes. According to 3.1.2, no new balls are introduced to the field until all balls that started the match have been scored. That implies the alliance must put all 3 balls into a goal somehow (if they started on the field. A team can decide 'their' ball be removed from the field - see G5)
Unread 05-01-2014, 13:20
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: missed shots
The auton stuff is still up in the air (I expect Team Update 1 to cover that). As far as a missed shot during teleop, if it goes out of bounds, it is given to the nearest human player per Section 3.1.2:
BALLS that are ejected from gameplay during a MATCH will be delivered to the closest HUMAN PLAYER of that BALL’S ALLIANCE by event staff at the next safe opportunity. This includes BALLS that go in GOALS but don’t meet the criteria to be considered SCORED.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 05-01-2014, 13:21
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
Re: missed shots
The rule book says that assists can only be scored during a cycle. Cycles are defined as starting when a ball is retrieved from the pedestal. This means that assist points are not available on auton balls. You can, however, still score them. possibly over the truss and catch too but I haven't looked into that rule.
Unread 05-01-2014, 16:14
Mvisw99 Mvisw99 is offline
FRC #2383 (Ninjineers)
Team Role: Scout
Mvisw99 is an unknown quantity at this point
Re: missed shots
What about missed shots in teleop? Can they be shot again and assist points count since the cycle doesn't technically end until the ball is scored?
Unread 05-01-2014, 16:32
Re: missed shots
That is one of my questions aswell
Unread 05-01-2014, 16:42
alectronic alectronic is offline
no team (Volunteer)
alectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant future
Re: missed shots
Per Glossary:
Originally Posted by Glossary
CYCLE: the series of events that recur regularly, and each CYCLE begins with an ALLIANCE’S BALL being retrieved from the PEDESTAL and ends when a BALL is SCORED in a GOAL.
and since points are awarded once per cycle
Originally Posted by Manual 3.1.4
Points are awarded once per CYCLE for BALLS SCORED by ROBOTS in the GOALS, BALLS SCORED by ROBOTS over the TRUSS, and for each ROBOT CATCH. Additional points are credited to an ALLIANCE upon each GOAL based on the number of ASSISTS earned by the ALLIANCE for that CYCLE.
that would imply that everything remains (score wise) until a CYCLE is completed.
Also, AUTO BALLS cannot receive TRUSS and CATCH points because those are part of a CYCLE and the AUTO BALLS are not part of a CYCLE.
Unread 05-01-2014, 17:16
Re: missed shots
Originally Posted by alectronic View Post
Per Glossary:
Thank you
Unread 06-01-2014, 21:35
Team Role: Scout
Re: missed shots
Thank you!
Unread 07-01-2014, 00:58
RallyJeff's Avatar
RallyJeff RallyJeff is offline
FRC Referee & FLL Many-Hats-Wearer
AKA: Jeff Hagan
Rookie Year: 1995
RallyJeff has a spectacular aura aboutRallyJeff has a spectacular aura aboutRallyJeff has a spectacular aura about
Re: missed shots
Per Glossary:
Would it? By my reading, "once per cycle" could simply mean that once the truss or catch points are awarded, they won't be awarded again until the next cycle.
Also, 3.1.4 spells out when truss and catch points are "scored" (i.e. when points are accrued), and they all refer to the point when the actual action occurs.
3.1.4 spells out the criteria for when the conditions for truss scores and catch scores are to be considered satisfied. If they're satisfied with the Auto balls (and it seems to me that they can be in theory, though it might be physically difficult to do without incurring a penalty), then why wouldn't they be scored?
My gut feeling - which may be completely wrong - is that they didn't intend for there to be this distinction where Auto balls aren't considered "part of a cycle". I hope that this gets clarified with an update.
Unread 07-01-2014, 08:46
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
Re: missed shots
This game forces teams to make choices you can play it safe or take a risk and get rewarded.
Unread 03-02-2014, 19:26
shindigo shindigo is offline
AKA: Mike Parker
FRC #0102
shindigo is an unknown quantity at this point
Re: missed shots
I'm still not clear on what can be done with balls that have not been scored in Autonomous and remain on the field. Has this been clarified yet?
- I assume we cannot score TRUSS and CATCH points with these.
- I assume that we cannot get assist points with these.
- I assume if scored, the team earns TELEOP high or low goal points for the score.
- I know they must be scored before a team can begin the first cycle.
I saw something somewhere about a team choosing to have their auto ball removed from the field. Was this only before autonomous? Can't imagine how you could do this after autonomous.
Unread 03-02-2014, 19:28
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
You have to score them and get the 1 or 10 points for the goal before you can start getting assist or truss or catch etc. points.
