Go to Post Teams that take care of the little things often have much less trouble with the big things! - dtengineering [more]
Unread 04-01-2014, 14:47
Chris is me's Avatar
AKA: Pinecone
Re: 2014 Rules Changes
Originally Posted by atlas View Post
in regards to the horizontal extensions. you can go out up to 20in in any direction correct? But does that limit you to one <20in extension at a time in the 6in cylinder? Or can you have more than one as long as they aren't 20in?
The six inch cylinder is an entirely different rule.
Vertically, any extending parts going higher than 5 feet can only be extended in the Goalie Zone and must fit within a 6" vertical cylinder.
Horizontally, you can extend 20 inches normal to the edge of any frame perimeter member. Height doesn't matter as long as it's under 5 feet. I have just read the rules but I do not remember anything limiting how many extensions are out at one time.
Unread 04-01-2014, 14:59
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
The six-inch cylinder rule only applies to vertical extensions.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 04-01-2014, 16:12
MasterEric's Avatar
MasterEric MasterEric is offline
Bacon. 'nuff said.
AKA: Eric Myllyoja (E2)
FRC #2137 (Oxford Robocats)
MasterEric is an unknown quantity at this point
Originally Posted by Jhultink View Post
So, let's say all 6 robots miss their auto points and the balls all stay on the field. How will the refs keep track of all the balls and assists?
Or will assists not count until all the auto balls have been scored? If this is the case, wouldn't it be better to have some of your alliance partners not even do auto so that you can get assist point in Tele-op quicker?
http://www.chiefdelphi.com/forums/sh...d.php?t=123985
You can't get assists in autonomous.
Unread 05-01-2014, 14:16
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I'm still in disbelief over this one, even after re-reading the rules and ctrl+f searching
The ridiculous Cv limit on pneumatic solenoid valves has been removed entirely
Unread 05-01-2014, 14:28
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
By Cv limit, do you mean flow rate? If so, this is big.
Unread 05-01-2014, 14:58
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
A quick search found this valve:
http://www.mcmaster.com/#6425k12/=q4ehnb
1/8" inlets with 1.0 Cv. Last years limit was .32 Cv.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 05-01-2014, 15:07
Hallry's Avatar
Hallry Hallry is online now
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Has no one yet said that matches are now 2:30, not 2:15?
Unread 05-01-2014, 15:12
Has anyone calculated whether this would actually improve the flow rate with the diameter tubing that is required?
Unread 05-01-2014, 16:17
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
I did. In the first post.
Unread 05-01-2014, 17:18
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
For a $130 each, would the improved performance really be worth it over a mechanical solution?
Academic Student (Forever)
Unread 05-01-2014, 17:47
AKA: Alan Wells
FRC #1350 (Rambots)
I think that it is just an example of a valve that is no longer illegal, not the best option. Also, what sort of mechanical solution exists for a small flow coefficient other than a larger flow coefficient?
Unread 05-01-2014, 18:00
CalTran's Avatar
MST Rolla Senior
I meant mechanical over pneumatic.
Unread 15-02-2014, 12:46
WeRrobots WeRrobots is offline
FRC #4125
WeRrobots is an unknown quantity at this point
During the autonomous period, do we have to start with the ball within the frame perimeter? Can we set it next to the bot and program the robot to pick it up?
Unread 15-02-2014, 12:51
I suggest reading rule G5, and telling me what "touching" means.
Unread 16-02-2014, 17:40
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Touching: arousing strong feelings of sympathy, appreciation, or gratitude. Kind of like New Math. How you feel about it is more important.
