Go to Post ...because "someone on ChiefDelphi said so," doesn't fly when your robot can't pass inspection. - Madison [more]
Unread 05-01-2014, 14:21
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
Re: Pass to Human Player
Originally Posted by alectronic View Post
You couldn't get ASSIST points because that would require a unique robot-zone pair, so a HUMAN PLAYER would not satisfy that requirement. Presumably, you could use a pass to a HUMAN PLAYER for something like getting around a defending robot from the opposite alliance, since it is easier for a human over a robot, in many cases, to maneuver the ball.
Assists are not based on passes, but possession. if a human player loads another bot, and that bot moves to another zone, the "assist" counts
2015 MAR District Champions
Unread 05-01-2014, 14:24
alectronic alectronic is offline
no team (Volunteer)
alectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant future
Right, I believe the original question though was if the HUMAN PLAYER received ASSIST points for being in a particular zone, which would be a no. But if they pass to a ROBOT, the ASSIST points are because of the ROBOT not the HUMAN PLAYER.
Unread 05-01-2014, 19:30
jimwick's Avatar
jimwick jimwick is offline
jim wick
FRC #0885 (the Green Team)
jimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of lightjimwick is a glorious beacon of light
It seems to us that a human play may be a good way to facilitate transfer between two bots. Maybe a "sending bot" can't send very accurately. Maybe a "receiving bot" isn't a very good fielder. A human player could get a sort of wild throw from the sender and carefully feed it toward the receiver.
Seems like a good strategy to us.
We see this as the real reason to have human players.
Unread 06-01-2014, 00:33
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
Can the human player score the ball?
The only rule I see possibly against it is
G36 A BALL inbounded after retrieval from the PEDESTAL must first contact a ROBOT or the carpet on its DRIVERS’ end of the FIELD before crossing beyond the TRUSS.
Violation: TECHNICAL FOUL
But that only is right after you take it off the pedestal, so you have to have a robot toss it to you first.
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
Unread 06-01-2014, 01:01
no team (Volunteer)
The rules state that the points are awarded for robot actions, which indicates a human could not score.
Originally Posted by Manual 3.1.4
Points are awarded once per CYCLE for BALLS SCORED by ROBOTS in the GOALS, BALLS SCORED by ROBOTS over the TRUSS, and for each ROBOT CATCH. Additional points are credited to an ALLIANCE upon each GOAL based on the number of ASSISTS earned by the ALLIANCE for that CYCLE.
(emphasis mine)
Unread 06-01-2014, 01:05
RallyJeff's Avatar
RallyJeff RallyJeff is offline
FRC Referee & FLL Many-Hats-Wearer
AKA: Jeff Hagan
Rookie Year: 1995
RallyJeff has a spectacular aura aboutRallyJeff has a spectacular aura aboutRallyJeff has a spectacular aura about
(emphasis mine)
3.14.A makes this especially clear:
A BALL is considered SCORED in an ALLIANCE’S GOAL if
A. a ROBOT causes one (1) of their ALLIANCE’S BALLS to cross completely through the opening(s) of one (1) of their ALLIANCE’S GOALS without intervening human contact,
Unread 06-01-2014, 01:49
brycen66 brycen66 is offline
FRC #1678 (Citrus Circuits)
brycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nicebrycen66 is just really nice
One good reason to pass to a human player is to gain the truss bonus, that is if you shoot over the truss.
Unread 06-01-2014, 02:06
chmorroni chmorroni is offline
chmorroni
AKA: Christopher Morroni
FRC #3729
chmorroni is on a distinguished road
Just looking at the field diagrams, that would be an interesting angle across the field. It would also involve moving backwards as far as field progress goes.
Personally, I agree that it may just be a way to make more teams' designs compatible with each other by having the human player as a go-between for the ball between 2 robots, so there can be more assists involved.
Unread 06-01-2014, 14:18
Qcom's Avatar
Qcom Qcom is offline
Gearhead
AKA: Quentin
FRC #2996 (Cougars Gone Wired)
Qcom is on a distinguished road
Originally Posted by ninjosh97 View Post
Yeah, our team usually spends the whole kickoff just reading the rules & thinking of basic strategies.
The rules are definitely more complicated than the last two years...
Honestly, as team rule guru I have found very little that is "specialized" to this year. The field has less interactive elements, and a very small amount of ways to score points. Carrying out team maneuvers such as assists, however, will probably be difficult to do in practice.
"The systems... They DON'T INTEGRATE!"
Unread 06-01-2014, 15:05
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
If a human player throws the ball to a robot, would that count as a catch (assuming the ball does not touch the ground)?
Does 3.1.4 imply that up to 3 catches per cycle can count (1 per robot) or that every catch (regardless of robot or number) counts?
3.1.4
We're planning on asking Q&A about this but I wanted to see what others take on these were.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 06-01-2014, 15:11
Dragonking's Avatar
Dragonking Dragonking is offline
AKA: Aaron Cannon
Dragonking is just really niceDragonking is just really niceDragonking is just really niceDragonking is just really niceDragonking is just really nice
No. A catch is when the ball possesses the ball after a truss shot, before the ball contacts the ground or a HP.
A CATCH occurs when a BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the carpet or HUMAN PLAYER.
An ALLIANCE receives CATCH points only if the CATCH is directly preceded by a TRUSS SCORE. This means that an ALLIANCE can only receive CATCH points once per CYCLE and will not receive CATCH points if the TRUSS SCORE criteria are not met.
2013-2014 Mechanical Subgroup, Scouting Captain
2015 Design Subgroup, Strategy Lead/Scouting Captain
