Go to Post Maybe someone should start a FIRST Anonymous meeting to try to help the tragicly addicted... - BiTurboS4 [more]
Unread 05-01-2014, 19:22
YCJeon772's Avatar
YCJeon772 YCJeon772 is offline
Mechanical Leader, CAD designer
AKA: Yuchan Jeon
FRC #0772 (SabreBytes)
YCJeon772 is an unknown quantity at this point
Catching a ball
Our team was brainstorming some ideas today, and one idea was to make a catching mechanism that would take up quite some space on our robot. Would catching be worth getting the extra 10 points? We did some calculations and it came out as having less cycles and spending more time trying to catch the ball. It can be a good resource to have among an alliance, but it would be hard to have it on the robot with other mechanisms that would be on the robot.
Unread 05-01-2014, 19:28
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: Catching a ball
If you can flawlessly integrate it into your robot and what you do, it's quite an asset to say "gimme the ball, coach". From what you're saying, it doesn't appear like you believe your catching system is very easily integrated.
As I said, if it's not really part of your system, unless it's so simple and small, let it go.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 05-01-2014, 19:35
erniep erniep is offline
AKA: Eclectic Polysyllabic Muse
FRC #0308 (Monsters)
Team Role: Mascot
erniep is on a distinguished road
Re: Catching a ball
So, is anyone catching (or throwing really)?? Just wondering what the thoughts are since we all are playing nice together this year.... Not that we're not nice to each other other years...it's just....well you know what I mean.
Unread 05-01-2014, 19:37
YCJeon772's Avatar
AKA: Yuchan Jeon
Re: Catching a ball
Alright. Did anyone think of trying to catch a ball with the same arm mechanism to pick up the balls from the ground? It would be more difficult, but could be possible to catch it in the air.
Unread 05-01-2014, 19:39
catacon catacon is offline
FRC #1444 (Lightning Lancers)
catacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to beholdcatacon is a splendid one to behold
Re: Catching a ball
Yes. And that's kind of what Zuelu562 is talking about. I see no reason why you could not make an all-in-one pick-up/catching/throwing mechanism. It all comes down to how you want to play the game and your team's abilities.
Unread 05-01-2014, 19:40
yash101 yash101 is offline
AKA: null
Re: Catching a ball
I came up with a design that can pick up balls from the ground, shoot (possibly full-court), pass and catch. However, it would be a hassle to get it within the dimensions because it involves completely enclosing the ball!
Check out the design here.
I haven't drawn the catching feature on it. However, just cut out a door at the top of the cage, move the conveyor belts to the side and build a hopper on top of the opening! Also, it is linear so it will also look kinda cool!
By the way, are we allowed to extend pass the chassey of the robot by, I believe 20 inches on each side, or is it just one side? If so, this is a perfectly feasible idea!!!
Unread 05-01-2014, 19:59
redsox11 redsox11 is offline
FRC #0348
redsox11 is an unknown quantity at this point
Re: Catching a ball
I have dreamt up a similar idea, except the full court shooting won't help you in this game per part B. And I'm 99% sure you get the 20" outside of your frame perimeter in all directions.
"A BALL is considered SCORED in an ALLIANCE’S GOAL if
A.a ROBOT causes one (1) of their ALLIANCE’S BALLS to cross completely through the opening(s) of one (1) of their ALLIANCE’S GOALS without intervening human contact,
B. the ALLIANCE ROBOT last in contact with the BALL was entirely between the TRUSS and their ALLIANCE’S HIGH GOALS, and
C. the BALL is not in contact with any ROBOT from that ALLIANCE."
Unread 05-01-2014, 20:00
Zealii's Avatar
Zealii Zealii is offline
#QuadSquad
FRC #3494 (The Quadrangles)
Team Role: Student
Zealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond reputeZealii has a reputation beyond repute
You can extend 20 in in every direction but must be inside frame perimeter when match starts
2014-Queen City Regional Finalists (868 & 3506)
2015-IndianaFIRST Kokomo District Finalists (5402 & 4982)
Unread 05-01-2014, 20:02
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Re: Catching a ball
Our team's game analysis method comes from Den Black, described here (part 1, part 2)
Before you ever even start talking about "how" you are going to build your robot, you should be doing a similar type of analysis to decide "what" you want to do and "why" you want to do it.
This year we have prioritized catching a ball quite high on our list of robot functionality. (I can't remember off the top of my head, but it might even be higher than high goal shooting.) One of the things we did in our analysis was figure out how quickly we could perform a teleop cycle if we had no help from alliance partners. The ability to catch a ball gives us either 1 or 2 additional cycles per match.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 05-01-2014, 20:20
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
Re: Catching a ball
I don't think you catch because of the extra 10 points. I think you catch because then no one has to chase down a bouncing ball that had a decent amount of energy imparted in it. Personally, unless you have enough resources to make an excellent thrower, I think its a really really good idea to concentrate on catching, even if it means you can't throw. You may not do so well in quals but I think you will see the value in elims, as it is a really quick assist.
Just make your robot a huge 5 foot tall target with 20 inch extensions, the whole thing padded to deaden the ball and some way to release it to the ground. If all else fails, you turn around and play the kind of defense where you're a 5 foot tall box that it is unlikely anyone can shoot over. This is just my personal opinion, and my team does not agree, and we will not be building this.
Unread 05-01-2014, 20:57
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
Re: Catching a ball
We considered this, and concluded that it makes more sense to have a catching mechanism on the rear of the robot and a top-roller floor pickup on the front, or somesuch.
The floor pickup is useful for retrieving balls, and can reverse its drive to be a floor spitter, to either do floor passes to other bots, or to put the ball in the low goal.
The catcher wants to be able to get balls from either human players or other bots. We will first try to make a human-tossed ball catcher, and see if it can be made big enough to accept balls from other bots. Bounce deadening is quite the thing.
Another idea, more crazy of course, is to make the ball catcher like a Venus flytrap, with wide-open hoops on the sides that close in on the ball as soon as a pressure sensor plate detects that a ball inside it.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Unread 05-01-2014, 21:02
AKA: null
Re: Catching a ball
If I understand you correctly, if you catch but have no way of ejecting the ball, you will screw the team because there is only one ball available at any time (of your color)
Unread 05-01-2014, 21:06
who716's Avatar
who716 who716 is offline
AKA: Stephen Kalogiannis
FRC #0716 (Who'sCTEKS)
who716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to beholdwho716 is a splendid one to behold
Re: Catching a ball
yes 100 percent to be honest I think catching will be the dark horse of this game if you can do it well and consistently it would be an absolute asset when coming to elimination. but you would also need to be able to score or throw to do well in qualifications when your partners are random. I myself have a few ideas im finalizing that are simple and doesn't take up much space. But you always have the option to have a separate catcher attachment that you can quickly attack onto the robot prior to a match depending on your partners that round I have a filling some teams will being doing this
-WPI number one seed
-Innovation in controls award
- NECMP#4 seed semifinalist
- 9th in NEW ENGLAND
2008- Connecticut regional winners
2004-UTC new England regional Winners
2001 highest rookie seed award winner
Unread 05-01-2014, 21:08
YCJeon772's Avatar
AKA: Yuchan Jeon
Re: Catching a ball
Well catching will be pretty difficult, considering that the ball is bouncy, and there is a chance that the mechanism may not successfully catch the ball every single time. In my opinion, it would seem to add time to each cycle if you tried to catch as well, since you now have to concentrate on catching a ball, and extra time to pick it up if it didn't catch properly. If you have a mechanism that will catch every single time successfully, then I can see how it can be faster.
Unread 05-01-2014, 21:46
who716's Avatar
Re: Catching a ball
have a catcher that doesn't catch the ball every single time wouldnt be any slower though because you would still be chasing a bouncy ball around the field but when you do catch you would safe time catching is important
