Re: Why only one ball?
It'd going to be hilarious....I described the game to my mom today, she could immediately imagine how much fun it will be to watch. I hope she can make it to the competition, to see her grandsons play ![]() |
Okay, so a few of us on 2338 think we are either missing something or we found something interesting.
First off, a few things. Is there anything that explicitly states a ball is on the pedestal to begin the match? We haven't found any... Next Quote:
Also Quote:
------------- If we are correct about this whole limited number of balls in a rotation, and there is not a stockpile, do you lose out by choosing for a goalie or choosing for someone not to take a ball? If this is true, you could end up with only two balls. I am already worried about the speed of the field worker being a variable to worry about, but if you only end up with 2 balls, it becomes even worse. |
http://www.youtube.com/watch?v=ERuue...qTbhru_5#t=107 Quote:
I understand that the pedestal will not light up until the last ball used during autonomous goes through the goal. That will allow only one ball after the 3 or less balls used during autonomous goes through the goal. What says that the ball cannot score in the goals. A CYCLE is defined as first starting from a lite pedestal, however that is for scoring ASSISTS. Does the manual every say that if you put those balls used during autonomous through the goals that they wouldn't score in the 10 point or 1 point goal during TELEOP?
#7
I think I found the answer to my own question reading with more intent.
3.1.4 Points are awarded once per CYCLE for BALLS SCORED by ROBOTS in the GOALS, BALLS SCORED by ROBOTS over the TRUSS, and for each ROBOT CATCH. Additional points are credited to an ALLIANCE upon each GOAL based on the number of ASSISTS earned by the ALLIANCE for that CYCLE. A CYCLE is the series of events that recur regularly, and each CYCLE begins with an ALLIANCE member retrieving their BALL from their lit PEDESTAL and ends when the BALL is SCORED in a GOAL. Major events in a CYCLE are depicted in Figure 3-1. Finding this bit of information about balls used in autonomous not being score is interesting. Teams will need to be very strategic about balls in play. |
#8
BUT Even 2008 World Champion team 1114, with Simbot SS being arguably the most dominant robot in FRC since 71 in 2002, was only consistently doing 6-7 hurdles in a match. I expect that a top team flying solo in 2014 will be able to achieve 6, maybe 7 1-assist cycles. Top alliances at championship will be lucky to push 5 3-assist cycles in a match. |
