Go to Post Hey, SHIFT HAPPENS.... - David Kelly [more]
Unread 05-01-2014, 21:34
xForceDee's Avatar
xForceDee xForceDee is offline
AKA: Bart Kerfeld
FRC #4239 (Warpspeed)
xForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to beholdxForceDee is a splendid one to behold
Rules on Pneumatic Cylinders
Currently I am thinking of possibly trying to punch the balls with a pneumatic cylinder. In the past, FIRST has put restrictions on things such as bore size and shaft length of the cylinder (at least I am pretty sure). I can't seem to find any rules regarding this in the rules however in the current manual. Could someone please stop me before I put a 10 inch bore diameter piston on my robot.
Unread 05-01-2014, 21:37
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Rules on Pneumatic Cylinders
Used to be you could only use a few specific sizes....that rule went away several years ago.
Unread 05-01-2014, 21:43
xForceDee's Avatar
AKA: Bart Kerfeld
So just to be 100% clear, there is no restriction on bore diameter or shaft length?
Unread 05-01-2014, 21:48
MrForbes's Avatar
AKA: Jim
If you don't see a restriction, it's because there isn't one.
keep in mind how much air the compressor can pump....I guess they figured out you don't need to be limited in size, because nature takes care of it.
Unread 05-01-2014, 21:53
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
The biggest change to this year is no Cv restriction on solenoids. This used to be pretty low, limiting airflow and making some things impractical. This year you can have a pretty high Cv solenoid allowing high airflow and making pneumatics more practical.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 05-01-2014, 22:43
Owen Makin Owen Makin is offline
FRC #1972
Owen Makin is an unknown quantity at this point
Can you please quote the rule, i could not find that change in the rule book. Thank you.
Unread 05-01-2014, 22:46
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
There was no rule restricting the CV on solenoids, so that would be why you can't find it. Therefor, any CV solenoid less than $400 is fair game.
Academic Student (Forever)
Unread 05-01-2014, 22:47
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
There is no rule-and that's the change. If you read the 2013 manual, it's letter C of R78:
C. Solenoid valves with a maximum 1/8 in. NPT port diameter, and a maximum Cv of 0.32,
That's from the 2013 manual, whereas R77 (the comparable entry in this year's manual) this year states:
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
There is no rule limiting CV. You can't quote a rule that doesn't exists.
4.10.4 R77
E. Additional pneumatic tubing, with a maximum 0.160 in. inside diameter, functionally equivalent to that provided
in the KOP,
These will be the limitations on flow so don't expect to fill a 2" cylinder quickly.
Unread 05-01-2014, 23:57
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
theirs no limit to the number of cylinders you can use though. so 3 1 inch cylinders have similar force to 1 larger cylinder yet you can have 3 inputs vs 1 so multiple small cylinders gives you faster extend time then 1 larger cylinder
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014-2016
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 06-01-2014, 00:04
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Depending on how they are plumbed, yes. however there are ways to do it and still restrict flow significantly, which should be avoided.
Unread 06-01-2014, 00:07
cmwilson13's Avatar
unless they have changed the rules and they may have the rules require 1 valve for 1 cylinder. so if its done that way you have significantly more flow
Unread 06-01-2014, 01:01
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
R90 prevents this, "The outputs from multiple valves may not be plumbed together"
Unread 06-01-2014, 06:33
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Hence using three small cylinders to do the job of one large cylinder.
Unread 06-01-2014, 13:43
FRC #1972
Thank you, and everyone else for their reply, our team wouldn't have noticed that small yet significant change.
