Go to Post I'm really impressed with how much effort we'll go to, to avoid buying a $25 servo tester. - MrForbes [more]
Thread Tools Rating: Thread Rating: 4 votes, 4.75 average. Display Modes
Unread 05-01-2014, 03:01
Zeromonkey's Avatar
Zeromonkey Zeromonkey is offline
NWFRCA Founder
AKA: Austin Kukay
FRC #2907 (Lion Robotics)
Zeromonkey is on a distinguished road
Re: How do we launch this thing? 2014
Originally Posted by Schnabel View Post
Welcome to the forum!
There's always this option.....
Quick Question:
Upon analyzing this, I can't seem to find how they are rotating the arm. Do you happen to know how they accomplished this?
"We can't solve problems by using the same kind of thinking we used when we created them." -Albert Einstein
"If you inspire those around you, they will grow more than you can possibly imagine." -Jack Harrison
“The man who moves a mountain begins by carrying away small stones.” -Confucius
Unread 05-01-2014, 13:03
BOSS BOSS is offline
FRC #2883
BOSS is on a distinguished road
Is it possible to use harvester similar to the ones used in rebound rumble. To take in the ball. Then raise up the harvester on an arm and reverse the motors shooting the ball up to make up the 2 feet into the goal. Plausible or is the fabric to big of a factor?
Unread 05-01-2014, 13:34
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
I have contemplated most of these designs, in addition to a cam design. Our team plans to test a pneumatic shooter, but does not predict great success.
Personally, I believe that Simbotics' 2008 robot has a very nice design that would work extremely well this year.
I believe that the best designs are wither something similar to Simbotics' 2008 shooter or some sort of cam with a huge boot attached to the corresponding "hammer". (Google "da Vinci cam")
Unread 05-01-2014, 14:13
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
What you want to accomplish with your launches will dictate how you launch.
Aerial shots:
-Lower angle (<45º line drive) high goal shots?
-Arching (~45º+) high goal shots?
-Over truss 45º shots?
-Over truss near vertical shots (robot keeps rolling and catches ball on other side of truss -no catch points; posession maintained)
-Over truss shots
Low to floor shots:
-Passing only?
-Low goal shots across floor?
-Robot-to-robot transfer/assist passing?
-Passing to human "shots"?
Handling all these well would require both a variable energy launcher and a variable angle launcher spanning nearly a 90º arch in the vertical plane.
A turret for targeting some amount to left-right might also be useful.
Our team is starting out building a surgical tubing powered ram launcher.
The ram will have an infinitely variable retraction tension cord winder with a trigger system that only accelerates the ram itself and the tension cord - no stored energy wasted on anything else - like a crossbow, but without the bow.
We are prototyping now to see how compact and short travel of a ram we can have while still shooting fast enough for consistent accuracy and adequate trajectory & travel.
We are not yet clear now many degrees the shooting angle of ram will need to be made adjustable. We also want to load balls as high up on the bot as possible, so shots cannot be easily blocked, and less energy needed to clear truss and hit the high goal.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
Unread 05-01-2014, 20:55
Mugurussa675 Mugurussa675 is offline
FRC #0675
Team Role: Driver
Mugurussa675 is on a distinguished road
Originally Posted by Maniac_Mechanic View Post
Ah, that glorious engineering question- how do we get this thing in the air?
I understand the ball is 24 inches wide and ~2.5 lbs. If anyone has more detailed numbers or tolerances, please add them.
Pyrotechnics are right out. They would totally set fire to the fabric. I'm sure the first thoughts everyone has are catapult arms. I was thinking about this and one of my sketches caused another problem appear. If arms are used to launch the ball, their own unladen weight will slow down acceleration of the ball or require a huge force to move.
I'm thinking broadly now. What if you used some much smaller arm that hits the ball and the impulse sends it flying? What can we come up with here?
Other things worth consideration:
The springs offered as part of the voucher http://info.vulcanspring.com/first-robotics-competition
They are constant force flat coil springs, not helical coil springs as you might picture.
How quickly will it be necessary to retract/ prime whatever launcher you have?
Try using surgical tubing and making a slingshot
FRC Team 675
Drive team
Team Leader
Manufacturing Leader
Unread 05-01-2014, 20:59
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
When I talked to my electronics team: "Why would we use pneumatics when we can have a crossbow!"
In all seriousness, linear punches sound really good this year. But prototyping will determine where we ultimately go.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 05-01-2014, 21:59
AKA: CAAAAAD
One way to make a piston into a possibly better shooting using a "simple machine" would be to attach a piece of chain to a piston and wrap the chain around a curved piece of aluminum which is then attached to a kicker.
I know this is a bad description, but basically, when the piston retracts, it pulls the kicker around a pivot point, creating a "knee" joint and a mechanical leg kicker.
Unread 05-01-2014, 22:12
TucoSalamanc TucoSalamanc is offline
TucoSalamanc is an unknown quantity at this point
Not an FRC-er, but a teacher that is shadowing the team at her future place of employment
From what I have seen so far, a flywheel is a perfectly viable solution. We used a flywheel on both sides of the ball each powered by a DEWALT 20-Volt Li-Ion Cordless Brushless Compact Drill. We had each going at about 2,500 RPM, which we believe is possible in the competition, spaced apart the recorded diameter will little luck. However, when we brought each in 1/5 inch the ball squeezed right through flying at the wall (10-25 feet away) and hitting with decent speed.
We took the rig outside (in heavy winds) and got recorded distances of 75ft lateral and what we believe to be 24 upwards (again, heavy winds). However, the ball popped after four throws. If you are confident in not completing more then four cycles, and have a blatant disregard for the sanctity of field elements, go for it. Too bad full-field tosses are illegal, because this thing is beastly.
Until then, we will be refining our shooter (Arial Accelerator, as the kids dubbed it) and work on getting videos up.
Unread 05-01-2014, 22:40
MMahoney's Avatar
MMahoney MMahoney is offline
FRC #0263
MMahoney is an unknown quantity at this point
I built a quick prototype pneumatic launcher today and was disappointed by how weak it shot. We did a variety of tests at different angles (~10 degrees, 45 degrees, and ~75-80 degrees) and found that the ball flew about 6-7 feet at highest. Barely enough to clear the truss.
Unread 05-01-2014, 22:48
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Interesting....I saw video of a different pneumatic launcher that today shot the ball briskly into the 10 ft high ceiling.
My guess is that you were not using the best geometry, cylinder size, valve type, or something.
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
What were the cylinder specs?
can you link that?
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 05-01-2014, 23:12
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
We are planning on using a catapult with surgical tubing as our strength, a hexagon to cradle the ball, and a shift and winch system. We also are planning on having a long kitbot with a high geared six motor drive train. One thing we are also weighing through is our floor feeder needs to be able to take hits and not shear off. And since we plan on having a long base, the ball is wider than our robot so a floor feeder above the ball will be hard to keep within the frame. We thought about two wheels on the side that grab it, than lift it into catapult, this would allow it to start in bumper zone then the feeder shoots down, we drive forwards, shoot, pull feeder up and maybe have three different programs that send the bot to different zones. I think several teams won't plan for this so we might see some breakage. One difference this year is that one robot can do it all (excluding goalie), all that is needed 1st is something that can shoot the ball into the high goal and over the truss, 2nd is the ability to pick balls up off the ground, 3rd is to be able to catch. I am thinking of putting bars up around the hexagon that aid in backstopping and catching, it will also help with defense?
Unread 05-01-2014, 23:18
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Could you (or anyone else who's trying this method) upload a video? I'd be interested in seeing your results.
-Plutarch
Unread 05-01-2014, 23:31
We can upload one once we get our new ball. It is pretty easy to test yourself if you have a couple of worn out grinding wheels for your drills. We sanded the grinding wheels of spurs, then a filler primer, and then we took them to the lab. If you lock your elbows, tape the trigger down, and hold it upwards you can achieve the same result without a brace. If the ball evens come close it is going to go flying, so be as safe as you can be in this.
Unread 05-01-2014, 23:45
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Team 701 plans to use a spring loaded linear slider system that gets pulled back by a winch to reset, and when a pass or toss is necessary, we disengage the winch pneumatically, and the energy stored in the spring tosses the ball. We proved this concept today with a slingshot type prototype that uses surgical tubing instead of a spring to store energy. We used an old custom winch and our 2013 robot to power it, and the ball was lifted more than five feet in our trials. Our next prototype will involve an actual spring, and we plan our springs to be tough enough that they can launch the ball a good height and distance, with only needing to compress the springs a mere few inches, and probably no more than six inches. We hope that this should save space and weight on our robot
