Go to Post If it walks like a duck, and talks like a duck could be a very clever animatronics display created by Disney Imagineers.... Sometimes it is just a duck. - IKE [more]
Unread 05-01-2014, 22:56
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: Reflective Tape on Robot
I was thinking more about a common agreement for alliance partner recognition to be applied via retro reflective tape in some pattern on each robot of an alliance. For instance, vision recognition of a triangle might be used to avoid passing to an opponent. Also could signal that the alliance partner is correctly oriented to receive a pass to even a non-automatic recognition system.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 05-01-2014, 23:02
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Well, for signaling correct orientation, I think green L.E.D.s in the area of your catching mechanism would be the way to go. They would also be handy to have on your ground-pass intake.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 05-01-2014, 23:10
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
I'm sure a standard design could be made (I've barely done vision tracking but I imagine something like 1 of these triangles would work).
Name:	Taget Triangle.png
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 06-01-2014, 00:24
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
I think that having yellow triangle displayed on the sides of your robot that teams should not pass to you so they can instantly tell not to just pass the ball to you, and have a green triangle with your current alliance color in the center of it on the side/where you want balls to be passed to you on/at. This way if your alliance partners will be able to tell instantly if they should pass the ball to you, and they wont have to worry about knowing what orientation is front and what side intakes are on all the robots every second.
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
