Go to Post They see us come into school looking like zombies, and they know that some people start smelling like chain lube and such...but for the most part, they don't realize that for a lot of us, there is a deep commitment to our team that we do a very large amount of work for that team. - JakeGallagher [more]
Unread 05-01-2014, 23:15
redneckrobot redneckrobot is offline
FRC #3840
redneckrobot can only hope to improve
Re: Ball eject
Originally Posted by pntbll1313 View Post
I'm not sure this really solves the issue. If you load your robot, start autonomous, and your robot never establishes connection for some reason, how does this deadman's switch work to release the ball so that your alliance can score?
that is the programmers job
Unread 05-01-2014, 23:17
FRC #3840
Re: Ball eject
use a "test for"
Unread 05-01-2014, 23:23
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Re: Ball eject
This would be good for the Q&A, maybe they could declare it field debris? Although how would a ref know to declare it as field debris if it is a result of power failure...?
Could they add a button to the alliance station to declare their current ball(s) field debris? That would add an interesting dynamic to the game (if they left the rule open ended).
If open ended, maybe an alliance could even do that to balls left from Autonomous.
If close ended though, let the rule be only for if the ball is trapped somehow.
Otherwise, the strongly robust robots might hold more weight in alliance selection...
FRC Team 539
Student Member: 2010 Breakaway - 2014 Aerial Assist
Mentor: 2015 Recycle Rush - present
Unread 05-01-2014, 23:30
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Re: Ball eject
Well, hypothetically, if you have 2 robots that can throw, none of the robots left available to pick can catch, and one of your robots has a multi-ball autonomous, the safest pick is a box (or ramp if you want to get fancy with loading) with a good drive-train under it.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 06-01-2014, 12:27
!Alp!
Posts: n/a
Re: Ball eject
A release is probably a good idea.
Unread 06-01-2014, 14:19
FRC #3840
Re: Ball eject
don't you get a redo if there is connection problems
so have a mechanical dead man switch incase there is lost of power
Unread 06-01-2014, 15:00
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: Ball eject
Sometimes. It really depends on if it's deemed a field fault or a robot fault.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 06-01-2014, 15:09
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Ball eject
It's irrelevant which it is. 2 robots on an alliance should never be put in a position where they cant score because some team is adamant in taking in the ball and then not being able to eject it.
Unread 06-01-2014, 15:36
Tungrus Tungrus is offline
Tungrus is just really niceTungrus is just really niceTungrus is just really niceTungrus is just really nice
Re: Ball eject
Our team is planning to join our alliance partner and beat the "ball' out of the third alliance with stuck ball! Pretty sure this is not against GS, which is directed towards opponent alliance and may get red card.
Unread 06-01-2014, 15:41
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: Ball eject
My only question would be, how do you design a mechanism that allows you to eject the ball when the robot dies, but NOT when the robot is disabled at the start of the match. I don't really see a simple way to do it.
On top of that, I have to believe that this is the kind of issue that will get addressed by the GDC in a game update or Q&A. I can't imagine they would make a game where one alliance could not score at all if one of their robots died... for that matter, what happens if both alliances have a robot die with a ball? No one scores at all that match? You could effectively have a game that is decided within the first 10 seconds, which doesn't make for a very interesting game.
Unread 06-01-2014, 15:52
AndrewPospeshil's Avatar
AndrewPospeshil AndrewPospeshil is offline
meme lord supreme
FRC #0503 (Frog Force)
AndrewPospeshil is a jewel in the roughAndrewPospeshil is a jewel in the roughAndrewPospeshil is a jewel in the rough
Re: Ball eject
I agree. Although we should never plan for new rules being added, I do think that this one has a good chance of happening. There's a few possibilities like a new ball being introduced if the robot controlling is inoperable and would otherwise stop the flow of the match, but there's a chance (and a sizable one in my opinion) that robots will be required to have removable balls so their alliance can still play if the team cannot. Which also presents the opportunity for the opposing team to be able to eject the ball somehow. Another element of strategy for teams to consider.
Unread 06-01-2014, 16:22
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Ball eject
Heh, this thread has uncovered a few issues, most of which have been addressed.
- Teams are usually not 100% honest about their capabilities because they're almost always trying to make themselves look good or haven't performed appropriate testing. A vast majority will say 'that cannot happen' or 'yea, but we fixed it' and thus it's really up to fate. I think the best approach it to be watchful after the first time it happens, weary that they couldn't fix it after the 2nd time, and politely assertive after the third. Scouting will be key.
- There will be scenarios, like many years, where a team will feel it may mathematically advantageous for them to keep a ball away from their own alliance in order to lose a match to fall in ranking and thus be available for a 2nd-round pick. It's been publicly discussed before and this year will be god-awful for the alliances which have a team member who exploits it. Hopefully this doesn't happen.
Single-solenoid valves are probably the simplest way of auto-ejection, but such a setup could potentially complicate setup and execution of autonomous. If the ball can't nestle nicely in the carriage ready for launch in steady state, then there's another variable for a consistent and reliable autonomous score.
GitHub
Unread 06-01-2014, 16:39
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Re: Ball eject
Or, even worse, a team holds onto a ball an entire match, so their superior partner cannot seed first, effectively breaking up any super alliances.
Teams that employ that strategy will likely join my extremely exclusive 'do no pick list'.
Unread 07-01-2014, 09:52
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Ball eject
Unfortunately, I see this happening more often than many would like to admit this year due to the way this rule seems to be worded. Hopefully a rule clarification will change this.
Mentor 2415
Unread 06-01-2014, 22:06
FRC #3840
Re: Ball eject
my team has come up with a pneumatic fail safe using a second cellanode
