E09_DRV_161213.7z Not Loading
We have the E09 classmate and I tried to re-image the classmate. Unfortunately, the tool stated that it could not find an image on the USB stick. If you open the RestoreDS.cmd file it has the following:
REM IMAGE MANIFEST REM Edit file names HERE where applicable to match deployment files REM REM REM ******************************** SET E09_Master=E09_2013_MASTER_09112012.wim SET E11_Master=E11_2013_MASTER_09112012.wim SET E12_Master=E12_2013_MASTER_09112012.wim SET E09_CPP=E09_CPP_2013_251112.wim SET E09_DRV=E09_DRV_2014_111113.wim SET E09_JAV=E09_JAV_2013_261112.wim SET E09_LAB=E09_LAB_2013_131212.wim SET E11_DEV=E11_DEV_2013_271212.wim SET E11_DRV=E11_DRV_2013_261212.wim SET E12_DEV=E12_DEV_2013_091212.wim SET E12_DRV=E12_DRV_2014_120913.wim All I did was correct the E09_DRV value using WordPad and restart the USB load. Everything worked OK. |
Re: E09_DRV_161213.7z Not Loading
This was mentioned on the KOP website: http://www.usfirst.org/roboticsprogr...control-system
