Go to Post Duct tape can fix everything except relationships with other people. - dixonij [more]
Unread 05-01-2014, 15:43
dtgriscom dtgriscom is offline
Mentor, Team 2713
AKA: Dan Griscom
FRC #2713 (iRaiders)
dtgriscom is an unknown quantity at this point
Legal ways of providing suction?
A number of the example robots in the game animation seemed to be possessing the ball using suction. I just mocked up a rig with a small shop-vac and a 5-gallon bucket, and it grabs and holds a ball (with cover) very well. Now I'm wondering: how can I legally provide that suction?
Rule R29 lists the allowed motors, and includes the following category: "Drive motors or fans that are part of a motor controller or COTS". In the glossary, COTS has very few limitations beyond "off-the-shelf", so could I buy and use a small 12VDC vacuum cleaner, driven by a Jaguar? (I'm dubious, because if this is covered by COTS then it seems like an enormous loophole for powered devices.)
Thanks,
Dan
Daniel Griscom
iRaiders Team 2713
Position: Mentor and Official Team Worrier
Unread 05-01-2014, 15:49
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: Legal ways of providing suction?
In the past, we made a custom duct around the turbine thing (I'm bad at explaining, I had very little to do with it's construction). It was powered with a legal motor (IIRC, it was a banebots).
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 05-01-2014, 16:03
Take your vacuum apart, remove the motor from the suction device, and replace it with a legal motor as close as possible to the suction motor.
You could also use a venturi device off the pneumatics system, but that's not going to work nearly as well.
Where you went astray was cutting off the rest of that line about COTS. The full line reads, "Drive motors or fans that are part of a motor controller or COTS computing device", which a vacuum is NOT.
Unread 05-01-2014, 16:09
Happy Birthday! czeke czeke is offline
Tool and Die maker/Tool Designer
AKA: Carl Zechel
FRC #1091 (Oriole Assault)
czeke has a spectacular aura aboutczeke has a spectacular aura about
You could also use an airbed inflator, in reverse, using a curved shield with a good rubber seal.
Unread 05-01-2014, 16:25
donkehote's Avatar
donkehote donkehote is offline
Design/Manufacture/Strategy Mentor
AKA: Kevin
FRC #5031
donkehote is just really nicedonkehote is just really nicedonkehote is just really nicedonkehote is just really nice
You can always disassemble the cots vacuum and remove the factory motor, replacing it with a first legal motor. Then it should be 100% ok. Might be a lot of work though.
Eric Ninjad me, darn. serves me right for not clicking submit reply
Unread 05-01-2014, 16:51
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Spend some time on repair sites looking at different shop vacs. Some 12 Volt (rechargeable) ones use 550 motors - we experimented with these in 2010 for holding the soccer balls.
Unread 05-01-2014, 16:56
Mentor, Team 2713
AKA: Dan Griscom
Oh, my goodness, is that confusing. In the decrypted PDF, the table in rule 29 ends at the bottom of page 17 with "Motor Name" given as "Drive motors or fans that are part of a motor controller or COTS", and "Max Qty Allowed" given as "Unlimited".
Then, at the top of page 18, "Motor Name" is given as "computing device", and "Max Qty Allowed" is given as "". Nasty, nasty, nasty. (And good catch, EricH. Thanks.)
ID:	15749  Click image for larger version
Daniel Griscom
iRaiders Team 2713
Unread 05-01-2014, 17:16
I'm using the PDF off the Manual site--clicking "Save As PDF"--and it's a LOT cleaner. I recommend you give it a try.
Unread 06-01-2014, 00:47
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Following this thread. Could be interesting.
Unread 06-01-2014, 01:33
dtengineering's Avatar
AKA: Jason Brett
Hmm... if only teams had a 3D printer they could make their own impeller design.
What's that? You've got a 3D printer you say?
http://www.thingiverse.com/thing:29623/#instructions
http://www.thingiverse.com/thing:7273
http://www.thingiverse.com/thing:13188
Might help get you started.
Jason
Unread 06-01-2014, 06:35
Mentor, Team 2713
AKA: Dan Griscom
Excellent idea: thanks.
Daniel Griscom
iRaiders Team 2713
Unread 06-01-2014, 07:00
loyal loyal is offline
Jack of all trades master of none
AKA: Loyal
FRC #0716
loyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to allloyal is a name known to all
Reading this reminds me of a seine in StarWars Phantom Menace during the pod race and the little robot got sucked in the turbine.
Unread 06-01-2014, 08:26
yash101 yash101 is offline
AKA: null
I think it's time for some machining . You could build a compressor-based suction-cup. However, that would generate a lot of suction, so you should really have a manual release valve.
How it works:
So you have a reciprocating piston, with an intake (suction) and an outtake (the atmosphere)
^=Output v=Suction intake
---^---v---
| Piston |
| |----------------Pushrod
Motor Crankshaft
Hopefully you guys liked my ASCII Art
I don't know if CD likes ASCII art
Name:	Screen Shot 2014-01-06 at 6.27.07 AM.png
Unread 06-01-2014, 08:38
Mentor, Team 2713
AKA: Dan Griscom
Won't work for any extended amount of time, because air leaks past the ball covering. You'd need continuous suction to maintain your hold for more than a couple of seconds.
Try the [code] tag; it will render using monospace fonts, e.g.
XXXXXXXXllllllll
llllllllXXXXXXXX
Daniel Griscom
iRaiders Team 2713
Unread 06-01-2014, 17:30
AKA: null
XXXXXXXXllllllll
llllllllXXXXXXXX
I'll try the code tag.
Also, the idea of the compressor is that it will continuously run when you want the ball to be held!
