Go to Post I too can find a method with correlation bias by applying a pattern to most datasets! - BrennanB [more]
  #31   Spotlight this post!
Unread 05-01-2014, 20:39
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Is throwing worth it ?
I think the important question here is, when will the High Rollers break a wall clock this year?
http://www.youtube.com/watch?v=raZdkGxq5Ig
  #32   Spotlight this post!
Unread 05-01-2014, 21:14
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Originally Posted by Alan2338 View Post
P.S. I might think this just because I don't believe catching is going to be a big deal...
Catch points aren't going to change many matches by themselves. However, it actually saves you time in the long run. Tossing the ball over the truss will send it bouncing the rest of the way across the field for the next robot to chase down if you don't catch it. If you do catch it then you can go right ahead and spit it out for that final assist or shoot quickly if you're the last robot in the line.
I see catching as a way to make what is essentially a really, really good pickup that also scores you bonus points.
  #33   Spotlight this post!
Unread 05-01-2014, 21:39
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
I have the same thoughts. I don't think catches will be common, but if a pair of robots can successfully pull off a truss throw/catch move, it gets a +30 point bonus in a single move (truss points, catch points, and at least a 2 assist) and is very hard to defend against. If the ball is high in the air traveling between the two robots there is no chance to block the ball during travel, and if you can't knock either robot out of position during the throw there's no way to defend it.
  #34   Spotlight this post!
Unread 05-01-2014, 23:22
G-Hence G-Hence is offline
FRC #1261
G-Hence is just really niceG-Hence is just really niceG-Hence is just really niceG-Hence is just really niceG-Hence is just really nice
Well time is an issue, but how much time is another thing. The rules don't really specify possession in time but rather control so theoretically, you could control the ball for lets say 2 seconds and you have the ball stopped and ready to assist given that you intake stops the ball quickly.
"Never let the fear of striking out get in your way."
-Babe Ruth
  #35   Spotlight this post!
Unread 06-01-2014, 09:59
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Reality check time. In another thread on defense it has been pointed out how easily a defensive bot can position adjacent to the low goal from either open side, and by placing a simple appendage into the low goal, they can prevent the ball from being scored there, from the front, the side, or the top openings.
Unless you can push them away from the low goal (not easy with them tucked in a corner) & score while holding them away, then you have only two options:
1) Win the race with them to the other low goal (assuming no other 2nd bot defender there already)
2) Score in the the high goal.
So, at least until there is rule clarification on whether this way of defending the low goal will be considered legal, it becomes a priority for every match alliance to have at least one member that is a fairly accurate high goal scorer.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
  #36   Spotlight this post!
Unread 06-01-2014, 10:08
MrForbes's Avatar
AKA: Jim
3) lob the ball into the top of the low goal, over the defending robot
  #37   Spotlight this post!
Unread 06-01-2014, 10:22
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Unless that robot is sitting INSIDE the goal, as has been questioned in other threads.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
  #38   Spotlight this post!
Unread 06-01-2014, 10:29
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Its only worth doing if you can go out and do it consistently.
This game is going to be all about execution in a match. Pretty much every team will design and build a robot that can pickup a ball and throw it into a goal. Things like catching the ball or throwing in the truss might not be carried throughout every robot but are easy to implement. The biggest game changer will be the teams who allow time for drive practice so they can go out and actually perform in a match.
1058 PVC Pirates 2016 - xxxx
  #39   Spotlight this post!
Unread 06-01-2014, 10:34
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Completely agree with this. I don't think design/manufacturing of robots this year is all too difficult as we've seen a game similar to this and there is no endgame. The skill of your drivers and the effectiveness of your strategies match to match will be the deciding factor of your success. Throwing will be a common trait among robots (IMO) and therefore your alliance should pick the best thrower to be the one scoring even if all of you can do it.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
  #40   Spotlight this post!
Unread 06-01-2014, 10:53
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
What makes you think we haven't already, Jim? We almost did worse...launched ball so hard it knocked off control boards from shelf at driver station wall in our shop. Turns out the joysticks are pretty durable.
"A genius is just a talented person who does his homework" T. Edison
  #41   Spotlight this post!
Unread 06-01-2014, 10:59
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Amen.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
  #42   Spotlight this post!
Unread 06-01-2014, 11:00
MrForbes's Avatar
AKA: Jim
Video or it didn't happen, Joe! you know the rules
  #43   Spotlight this post!
Unread 06-01-2014, 11:35
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Celia View Post
Having a shooter means getting nine - or nineteen - more points per cycle rather than going for the low goal with no truss pass.
Beware the No Truss-Passing signs!
  #44   Spotlight this post!
Unread 06-01-2014, 11:42
zsm150's Avatar
zsm150 zsm150 is offline
AKA: Zack Moore
FRC #0314 (Big Moe)
zsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to beholdzsm150 is a splendid one to behold
Originally Posted by Team3266Spencer View Post
But the ball has a 12 inch radius, so I imagine it wouldn't be that difficult to push in.
This is a assuming that you have a solid driving team that is prepared to control a ball of this size. Speaking from our teams decisions, our chassis is only 27in wide meaning there is only 1.5 inches of play on each side of the ball if it is centered. Just bumping the ball down the field could possible result in unreliability in terms of accuracy of your passing as well as another team can hit your ball out of your possession and push your bot around as much as they want. I would recommend a system that could keep control of the ball while you are moving
  #45   Spotlight this post!
Unread 06-01-2014, 12:57
Keegbot's Avatar
Keegbot Keegbot is offline
AKA: Keegan McCrary
FRC #2438 (Beta Blues)
Keegbot is an unknown quantity at this point
I think throwing is worth it because scoring in the low goal is relatively easy to do and defend and being able to shoot in the high goal will add diversity to your attack and make you harder to defend. Also, truss points are added to the score as soon as it is thrown (or caught) so if you are at the other end of the field at the end of a match than you could quickly score 10 and a possible 20 points and save the time of having to drive to the other end or pass it to other robots for them to score. I definitely think it is worth it to at least be able to throw.
