Go to Post Then there's the electronics, pneumatics, and all that stuff on top that will magically make the ball score billions of points. That will add up to a lot of weight. - MrForbes [more]
Unread 06-01-2014, 11:05
Alfaa123's Avatar
Alfaa123 Alfaa123 is offline
CRT Master Race
FRC #5196
Alfaa123 will become famous soon enough
Using a "railgun launcher" or a long-travel solenoid
Has anyone thought about this? Knowing FIRST, there is probably a rule that prevents you from drawing large amounts of current from the battery to build a sort of "electronic pneumatic launcher" but I haven't seen much about it at all.
Pneumatics seems to be the best option to get a quick, powerful pushing force, but I always like to talk about alternatives.
And also because saying you have a railgun on your robot would be pretty awesome.
Unread 06-01-2014, 11:18
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
Re: Using a "railgun launcher" or a long-travel solenoid
I don't think FIRST has any rules about current draw. Your 120 amp breaker might have something to say, however.
Unread 06-01-2014, 11:28
DonRotolo's Avatar
Back to humble
FRC #0832
The rule of physics prevents you from drawing excessive current through that 120A breaker.
Do you think pneumatics are faster than, say, a big rubber band?
Unread 06-01-2014, 11:31
Alfaa123's Avatar
CRT Master Race
FRC #5196
Oh yea, that was another option that I forgot to mention.
You don't think that you can make an electromagnet powerful enough to get that ball AT LEAST as far as pneumatics can? And I'm genuinely wondering. I haven't actually seen a solenoid other than those for pnumatics.
Also, are there rules preventing you from stepping up the voltage and using a big capacitor to store for a pulse?
Unread 06-01-2014, 11:59
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Originally Posted by FRC Game Manual
Electrical solenoid actuators, no greater than 1 in. stroke and rated electrical input power no greater than 10 watts (W) continuous duty at 12 volts (VDC)
(Emphasis mine)
I think that this would be your biggest problem for that strategy.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 06-01-2014, 12:00
Knufire Knufire is offline
For electric solenoids, R29 (the list of allowed motors and actuators) states:
Electrical solenoid actuators, no greater than 1 in. stroke and rated electrical input power no greater than 10 watts (W) continuous duty at 12 volts (VDC) - Unlimited
For custom circuits, R40 states:
Any active electrical item not explicitly listed in R29 or R67 is considered a CUSTOM CIRCUIT. CUSTOM CIRCUITS may not produce voltages exceeding 24V when referenced to the negative terminal of the battery.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 06-01-2014, 12:01
Alfaa123's Avatar
CRT Master Race
FRC #5196
Originally Posted by Whippet View Post
(Emphasis mine)
Yep. Looks like that's not going to be viable..
