Go to Post We're basically using a two step process: 1. Smoke 2. Mirrors - Tom Bottiglieri [more]
Unread 06-01-2014, 10:33
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Lack of CV limit and what to do about it
How should one go about selecting a solenoid valve that has a higher cv limit?
What things should you look for when buying one?
I imagine, most teams have a similar knowledge base on this as I do. Which is, this is the solenoid we use because we have to. Now that we can select our own, what do we do?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 06-01-2014, 11:47
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Lack of CV limit and what to do about it
First, what function does it need? Single, double, whatever.
Second, does it comply with the rules (e.g., 1/8" NPT input)?
Third, can you afford it?
Note that the 'regular valves we always used' are pretty good for the 0.160" ID tubing we get to use, having a significantly larger Cv isn't going to do much.
Unread 08-01-2014, 11:32
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
True, but there was an inexpensive valve (less than $40) that I recall finding a few years ago that we could not use because of Cv either being slightly higher or the spec was unavailable..... now if I could only remember where it was.....
This opens up a larger selection, and simplifies the documentation for teams and inspectors, with minimal change in performance.
