Go to Post One of my management professors taught me this: At all times you are holding a bucket in each hand, one full of water, and one full of gasoline. Management is knowing when to throw which bucket. - Barry Bonzack [more]
  #31   Spotlight this post!
Unread 06-01-2014, 11:49
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
Re: Ball eject
Originally Posted by Whippet View Post
What about the robots in 2012 with the after-the-buzzer pneumatic bridge balancers?
You had to trigger the solenoid before the buzzer. Any after-buzzer activity was just the air pressure equalizing on a decision that had already been made.
  #32   Spotlight this post!
Unread 06-01-2014, 12:27
!Alp!
Posts: n/a
Re: Ball eject
A release is probably a good idea.
  #33   Spotlight this post!
Unread 06-01-2014, 13:51
Racer26 Racer26 is offline
Re: Ball eject
Not strictly true. You can have a single acting solenoid valve which spends the entire match energized, keeping your ball ejector retracted. As soon as the robot transitions to the disabled state (either commanded by the field at the end of a match, or because the robot lost communication) that solenoid will cease to be energized, and extend your ball ejector.
The trick is in figuring out a way to either A) make it so that during the pre-match disabled phase you can keep your ejector retracted (perhaps you use a dump valve connected to a servo to trap air strategically in the system that can later be released) OR B) pick the ball up at the start of auto instead of pre-loading it into your robot.
  #34   Spotlight this post!
Unread 06-01-2014, 14:16
Dalrik Dalrik is offline
FRC #0639 (Code Red Robotics)
Dalrik is an unknown quantity at this point
Re: Ball eject
This is probably what most teams are going to have to do. The corner case of a robot that crashes as soon as auton starts and thus never has time to arm an eject mechanism is one that I don't see a clear solution for. Then again, you have to waste part of your 5 second window for the hot goal picking up the ball...
  #35   Spotlight this post!
Unread 06-01-2014, 14:19
redneckrobot redneckrobot is offline
FRC #3840
redneckrobot can only hope to improve
Re: Ball eject
don't you get a redo if there is connection problems
so have a mechanical dead man switch incase there is lost of power
  #36   Spotlight this post!
Unread 06-01-2014, 15:00
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: Ball eject
Sometimes. It really depends on if it's deemed a field fault or a robot fault.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
  #37   Spotlight this post!
Unread 06-01-2014, 15:09
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Ball eject
It's irrelevant which it is. 2 robots on an alliance should never be put in a position where they cant score because some team is adamant in taking in the ball and then not being able to eject it.
  #38   Spotlight this post!
Unread 06-01-2014, 15:36
Tungrus Tungrus is offline
Tungrus is just really niceTungrus is just really niceTungrus is just really niceTungrus is just really nice
Re: Ball eject
Our team is planning to join our alliance partner and beat the "ball' out of the third alliance with stuck ball! Pretty sure this is not against GS, which is directed towards opponent alliance and may get red card.
  #39   Spotlight this post!
Unread 06-01-2014, 15:41
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Re: Ball eject
My only question would be, how do you design a mechanism that allows you to eject the ball when the robot dies, but NOT when the robot is disabled at the start of the match. I don't really see a simple way to do it.
On top of that, I have to believe that this is the kind of issue that will get addressed by the GDC in a game update or Q&A. I can't imagine they would make a game where one alliance could not score at all if one of their robots died... for that matter, what happens if both alliances have a robot die with a ball? No one scores at all that match? You could effectively have a game that is decided within the first 10 seconds, which doesn't make for a very interesting game.
  #40   Spotlight this post!
Unread 06-01-2014, 15:52
AndrewPospeshil's Avatar
AndrewPospeshil AndrewPospeshil is offline
meme lord supreme
FRC #0503 (Frog Force)
AndrewPospeshil is a jewel in the roughAndrewPospeshil is a jewel in the roughAndrewPospeshil is a jewel in the rough
Re: Ball eject
I agree. Although we should never plan for new rules being added, I do think that this one has a good chance of happening. There's a few possibilities like a new ball being introduced if the robot controlling is inoperable and would otherwise stop the flow of the match, but there's a chance (and a sizable one in my opinion) that robots will be required to have removable balls so their alliance can still play if the team cannot. Which also presents the opportunity for the opposing team to be able to eject the ball somehow. Another element of strategy for teams to consider.
  #41   Spotlight this post!
Unread 06-01-2014, 16:22
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Ball eject
Heh, this thread has uncovered a few issues, most of which have been addressed.
- Teams are usually not 100% honest about their capabilities because they're almost always trying to make themselves look good or haven't performed appropriate testing. A vast majority will say 'that cannot happen' or 'yea, but we fixed it' and thus it's really up to fate. I think the best approach it to be watchful after the first time it happens, weary that they couldn't fix it after the 2nd time, and politely assertive after the third. Scouting will be key.
- There will be scenarios, like many years, where a team will feel it may mathematically advantageous for them to keep a ball away from their own alliance in order to lose a match to fall in ranking and thus be available for a 2nd-round pick. It's been publicly discussed before and this year will be god-awful for the alliances which have a team member who exploits it. Hopefully this doesn't happen.
Single-solenoid valves are probably the simplest way of auto-ejection, but such a setup could potentially complicate setup and execution of autonomous. If the ball can't nestle nicely in the carriage ready for launch in steady state, then there's another variable for a consistent and reliable autonomous score.
GitHub
  #42   Spotlight this post!
Unread 06-01-2014, 16:30
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
Re: Ball eject
Single action solenoids are great but if you don't have pneumatics on your robot (and many teams don't), it shouldn't be necessary to add an entire pneumatic system for that.
  #43   Spotlight this post!
Unread 06-01-2014, 16:39
atucker4072's Avatar
atucker4072 atucker4072 is offline
Andrew Tucker
AKA: Andrew Tucker
FTC #4968 (Rapid Robotics)
atucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura about
Re: Ball eject
You have a good point but having a pneumatics system is better than loosing matches.
  #44   Spotlight this post!
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
FRC #1732
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Re: Ball eject
Or, even worse, a team holds onto a ball an entire match, so their superior partner cannot seed first, effectively breaking up any super alliances.
Teams that employ that strategy will likely join my extremely exclusive 'do no pick list'.
  #45   Spotlight this post!
Unread 06-01-2014, 19:49
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Ball eject
Originally Posted by RSaunders View Post
Why wouldn't the referees consider a ball in an EStopped robot "out of play"? It's a good idea to raise this question in the Q&A, but software solutions aren't what you want when a simple human decision can solve your problem. That's what referees are for.
/Randy
A referee's job is to enforce the rules, not make up new ones. As much as we'd sometimes like to help out teams, we can't do so if the rules don't allow it. If the rules are amended to define a ball in an E-Stopped robot as field debris, we will so decide. If the rules remain as is, we can't do it.
(since 2004)
