Go to Post since when is not sleeping, caring more about the robot and such bad for you? If it is how come I didn't get the memo? :ahh: - Sakura141 [more]
Unread 11-02-2003, 19:48
blindguy blindguy is offline
blindguy is an unknown quantity at this point
Send a message via AIM to blindguy
More drill motor problems, jeeze.
Hey i got another problem not brought up yet. To you remove the pins you take the top blu part off the black bottom part. Ok well our motor begun doing that by itself during operation. Any sugeestions.
wish i wasnt a dern rookie,
matt
Unread 12-02-2003, 06:23
Iain Iain is offline
Iain is an unknown quantity at this point
One motor of ours actually did this once too - but only after it snapped the white clutch ring in two places. Though the ring was already cracked before it did that...
Unread 12-02-2003, 08:24
Just a guess,
You had the transmission mounted in one spot. When the drive delivered power either the front (the clutch assy) turned or the transmission turned. Since the clutch is a twist and lock onto the front of the transmission, you must secure both pieces to prevent them from twisting apart.
Unread 12-02-2003, 08:42
Caleb Fulton's Avatar
Caleb Fulton Caleb Fulton is offline
Z = Z^2 + C ......WHEEEE!
AKA: aXvXiA
#0461 (West Side Boiler Invasion)
Caleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura aboutCaleb Fulton has a spectacular aura about
Send a message via AIM to Caleb Fulton
The key to mounting these things (as far as rotation/torque is concerned), based upon the design of the motor mounts supplied by first, is securing and holding down the two small black thingies toward the front and on the top of the tranny that are sticking out a bit (they are about 1/2" long). I'm not sure if this would help, any...
Unread 12-02-2003, 09:06
Ian your silly posting a reply to your own teams post.
I thought the key was in the mountings too. My teacher seems to think adding spacer between the hex and the gear box.
matt
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
A new record for breaking a drill motor ZacharyD Technical Discussion 23 16-01-2003 16:58
