Go to Post It doesn't matter what goes wrong as long as you have fun. We all thought this was one of our best trips, even though we were second to last in our divison. - afowl [more]
Unread 06-01-2014, 14:17
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
Re: Mecanum vs Omni vs KOP wheels
What do you mean by omni wheels? Do you mean to put them in to a drive base that is omnidirectional or put then on a drive that is like the KOP base?
Unread 06-01-2014, 14:49
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Yeah, mecanum and omni do no perform the same, and require very different configurations.
Omni allow for rotation with less frictional resistance, and also some sliding.
Mecanum are individually powered wheels that are designed to allow for more directions of powered motion.
Unread 06-01-2014, 14:51
mechlectrician7's Avatar
mechlectrician7 mechlectrician7 is offline
FRC #0894 (Powers 894)
Team Role: Electrical
mechlectrician7 is an unknown quantity at this point
My team has used all three types of wheels at one point or another. Personally i prefer to use omni wheels, for the reason, if you know how to set them up, you can do the same things as mecanum wheels (but you would need 6 to do so), and they are a little more durrable. (Atleast from what i've seen) In the previous game, my team used mecanum...but not he highest of quality. I have nothing against mecanum wheels but if u are to use them you should definantly invest in the higher quality.
Unread 06-01-2014, 15:04
SenorZ's Avatar
Physics Teacher
AKA: Tom Zook
Do you have the 5 and 6 wheels mounted transversely?
Unread 06-01-2014, 15:28
...i prefer to use omni wheels, for the reason, if you know how to set them up, you can do the same things as mecanum wheels (but you would need 6 to do so)
You don't need 6. You can do it with 4.
Unread 06-01-2014, 15:43
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
There are plenty of wheel options out there. Consider what your design priorities are, and then select wheels to match them.
http://www.andymark.com/Wheel-s/229.htm
http://www.vexrobotics.com/vexpro/wheels-and-hubs
http://banebots.com/c/WHB
http://www.robotmarketplace.com/prod...eels_main.html
You can "do it" with 3, actually. Assuming by "do it" you mean transverse in two different axes independent of any frame rotation.
Unread 06-01-2014, 16:21
Pi3th0n Pi3th0n is offline
AKA: Chase Mansell
FRC #0900 (Zebracorns)
Pi3th0n is on a distinguished road
Honestly, for this game I can't think of a good reason to not use the KOP or some other high-traction wheel. Since opponent robots can't "possess" your ball, they'll defend by pushing around your robot. If you have high-traction wheels you won't get pushed around very much, but with mecanum's or omni's you'll be stuck on the wrong side of the field. Our team's driver last year was able to keep two mecanum bots on the wrong side of the field single-handedly for about half the match!! Very amusing to watch, certainly frustrating for the drivers of the mecanum bots.
Unread 06-01-2014, 20:36
Keegbot's Avatar
Keegbot Keegbot is offline
AKA: Keegan McCrary
FRC #2438 (Beta Blues)
Keegbot is an unknown quantity at this point
The reason I'm in favor of mecanum is to catch the ball because it will allow you to maneuver to the ball easier than tank would. It will also help you chase down balls faster if your alliance partner is an inaccurate passer than tank would.
Unread 07-01-2014, 12:37
Oblarg Oblarg is offline
AKA: Eli Barnett
Your first point seems valid. I'm not so sure about the second.
"The breakfast of champions!"
Unread 07-01-2014, 12:56
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Imagine playing Rebound Rumble with the goals moving. It's way harder. A catcher should be stationary, make it easy for your thrower to hit you. There should be no trouble making a very consistent ball-launcher.
Sure, you may be able to adjust to catch a ball on your practice field, but when you get pushed across the field for 2:20 you won't be a very effective catcher.
Unread 07-01-2014, 13:04
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
That was on a field with Pyramids vs. an open field.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 06-01-2014, 16:19
True, my apologies
