Go to Post A stack is a stack is a stack. (How Profound!) - Paul Copioli [more]
Unread 06-01-2014, 14:29
Breakaway3937's Avatar
Breakaway3937 Breakaway3937 is offline
Director
AKA: Brian "Robo" Jones
FRC #3937 (Breakaway)
Breakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really niceBreakaway3937 is just really nice
Re: Why only one ball?
Originally Posted by alectronic View Post
You never have to take a ball. But any ball you take in auto must be put into a goal before you can score ANY points in teleop.
I understand that the pedestal will not light up until the last ball used during autonomous goes through the goal. That will allow only one ball after the 3 or less balls used during autonomous goes through the goal. What says that the ball cannot score in the goals. A CYCLE is defined as first starting from a lite pedestal, however that is for scoring ASSISTS. Does the manual every say that if you put those balls used during autonomous through the goals that they wouldn't score in the 10 point or 1 point goal during TELEOP?
"There is no luck. It is only when preparation meets opportunity."
Unread 06-01-2014, 14:43
Director
I think I found the answer to my own question reading with more intent.
3.1.4
Points are awarded once per CYCLE for BALLS SCORED by ROBOTS in the GOALS, BALLS SCORED by ROBOTS over the TRUSS, and for each ROBOT CATCH. Additional points are credited to an ALLIANCE upon each GOAL based on the number of ASSISTS earned by the ALLIANCE for that CYCLE.
A CYCLE is the series of events that recur regularly, and each CYCLE begins with an ALLIANCE member retrieving their BALL from their lit PEDESTAL and ends when the BALL is SCORED in a GOAL. Major events in a CYCLE are depicted in Figure 3-1.
Finding this bit of information about balls used in autonomous not being score is interesting. Teams will need to be very strategic about balls in play.
Unread 06-01-2014, 20:57
AwesomeCoding's Avatar
AwesomeCoding AwesomeCoding is offline
Cheif Overlord Of Awesomeness
AKA: Nick Jones
FRC #2046 (Bear Metal)
AwesomeCoding is an unknown quantity at this point
Originally Posted by austin4169 View Post
It seems like only one ball is in play during the teleop period, which really doesn't make any sense:
I would think more time would be spend with human players running around with balls outside the field than will be spent with the balls being controlled by the robots. Did I get something wrong? thoughts?
The point of having one ball is to add emphasis on teamwork.
With only one ball, you have to work with your alliance members.
Unread 07-01-2014, 10:07
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Precisely. Lets say we had 3 balls in play. If all 3 robots could score, that's WAY faster than trying to get a 2 assist truss cycle, and you get the same points. Cycles and speed of them will be important. I'm expecting minimum 3 2-assist cycles for a decent alliance, and I wouldn't be surprised to see upwards of 4 or 5 2-assist cycles for a very good alliance (I would put a 3-assist truss catch cycle at 3-per-game for a very good alliance)
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 07-01-2014, 13:26
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
... and this is WHY there is only 1 ball. It forces teamwork (which I believe is a good thing).
Cycles and speed are very important, but in this game strategy and teamwork will determine winners far more than just machine design.
___________________
- Tennyson, Ulysses
Unread 07-01-2014, 14:13
c.shu's Avatar
c.shu c.shu is offline
Alumni/Mechanical/CAD
AKA: Cole Shumaker
c.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to behold
I think the reason there is only one ball is to level the playing field.
By only having one ball it prevents one stellar robot from dominating the competition all through qualifications. A team of 3 average bots can overcome the one by using a little bit of teamwork. Therefore, the great bot will need even better teamwork if they want to win. They can't do it by themselves.
In a sense, this teaches us we can't do it alone, but we need to use those around us to succeed.
