Go to Post If it gets people talking about not only robots but science and technology, it's all good. - Koko Ed [more]
Unread 25-02-2010, 11:24
The Engineer The Engineer is offline
FRC #2607
The Engineer is an unknown quantity at this point
Xbox 360 controllers
I am relatively new to java and i was wondering if anyone has gotten a xbox360 controller was using one. If so how do you hook it up? Can you just use the Joystick class in java? and How do you distinguish between axises in java? any answers would be greatly appreciated and I do have a wireless and a wired controller if that makes it easier.
Unread 25-02-2010, 11:46
Jared Russell's Avatar
Taking a year (mostly) off
Re: Xbox 360 controllers
We are using a wired Xbox 360 controller in Java with no problems. Just install the drivers on the Classmate, plug it in, and access it using the Joystick class.
For more information, and a mapping of controller axes to Joystick class axes, see: http://www.chiefdelphi.com/forums/sh...threadid=82825
Unread 25-02-2010, 12:03
FRC #2607
I can get the Xbox360 controller hooked up but actually using it to drive in java with multiple joysticks on the controller and if someone could tell me what buttons are what in java?
But the thing I really don't understand is how you get multiple joysticks on the controller working and pick one to use?
Unread 25-02-2010, 12:39
Read the link in my reply.
Axis indexes:
1 - LeftX
2 - LeftY
3 - Triggers (Each trigger = 0 to 1, axis value = right - left)
4 - RightX
5 - RightY
6 - DPad Left/Right
Button mapping matches Windows Control Panel>Game Pads display
So you define the Joystick like:
Joystick mXboxController = new Joystick(1); // Where "1" is the index of the joystick (you can set this in the Driver Station software).
To read an axis (like the left stick Y axis), simply do:
double axisValue = mXboxController.getRawAxis(2); // Where "2" is the index of the Y axis on the left stick (see above)
To read a button, simply do:
boolean buttonPressed = mXboxController.getRawButton(1); // Where "1" is the index of the button reported by the Windows Control Panel "Game Controllers" display
Unread 25-02-2010, 13:08
FRC #2607
Thank you so much this has been a huge help the only thing i need now is the button layout and i can get that
Unread 25-02-2010, 23:55
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Robototes2412 is on a distinguished road
just remember to set a buffer b/c the sticks are waay too sensitive
Unread 26-02-2010, 00:04
Chris is me's Avatar
AKA: Pinecone
Specifically, the sticks don't return to the same position when you let go, so you'll want to program in a small (10 in each direction) deadband so that you don't have crawling robots.
Unread 26-02-2010, 11:36
FRC #2607
and how exactly do you set that in the code
Unread 26-02-2010, 11:44
AKA: Pinecone
I'm not sure on the FRC specifics, but assuming a range of 0-255 with 127 being the middle (I dunno if that's how Xbox joysticks are defined so adjust accordingly)... just if (xBox < 140 || xBox > 110) { return 127;} or something like that.
Unread 06-01-2014, 14:41
puneeth.meruva puneeth.meruva is offline
MIT Class of 2019
AKA: Puneeth Meruva
FRC #1501 (Team T.H.R.U.S.T)
puneeth.meruva will become famous soon enoughpuneeth.meruva will become famous soon enough
How can you use the left stick on the xbox controller to program an arcade drive on Java? Furthermore, how can you take input from the bumpers and the X,Y,B, and A buttons? Any sample code would be appreciated.
Unread 06-01-2014, 18:17
Do you understand how to program an acrade drive with a joystick? Do you understand how to read a button from a joystick?
Unread 06-01-2014, 18:40
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
This post with code may help.
Unread 10-01-2014, 12:07
MIT Class of 2019
AKA: Puneeth Meruva
I am familiar with programming a tank drive, but I am unsure of how to program an arcade drive with a joystick. I know how to read joystick input from the xbox controller, but I am still slightly confused about how to read input from the letter buttons on an xbox controller.
Unread 10-01-2014, 21:20
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Dustin Shadbolt is on a distinguished road
Originally Posted by Dustin Shadbolt View Post
This should be useful to you Puneeth.
Also, there are some example code posts here on CD. I'll link to one post where there is some example Java code to get you pointed in the right direction on how to program your Arcade drive. Great thread
Unread 10-01-2014, 22:32
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
In Java, you would need some kind of control loop.
if(Math.abs(xboxControler.getRawAxis(2)) > .1)
    //do something
In the above example, the loop checks and makes sure that the value of the stick is above the "dead band" whether it is positive or negative.
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
Xbox 360 controller viper110110 Programming 7 18-02-2010 19:58
Logitech or Xbox 360 Controllers? JohnFogarty Programming 11 08-02-2010 22:51
XBox 360 Joe Matt Chit-Chat 83 29-11-2005 15:18
Xbox 360 zdeswarte General Forum 1 11-05-2005 14:53
