Go to Post Mentors are the guardrails: Show the students how to do what they need to do, Step back and let the students do what they need to do, Nudge them back on course when they need a nudge, Insist, when necessary, that no one tries to juggle the chainsaws - gblake [more]
Unread 06-01-2014, 13:47
redneckrobot redneckrobot is offline
FRC #3840
redneckrobot can only hope to improve
gun barrel
dose any one know ho to make a barrel that is 26" id
55 gallon barrel is to small 60 gallon is to big
cant find abs/pvc pipe in short segments
pleas help
Unread 06-01-2014, 13:53
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: gun barrel
Does it have to be airtight? Have you considered ventilation ducts?
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 06-01-2014, 13:58
Owen Makin Owen Makin is offline
FRC #1972
Owen Makin is an unknown quantity at this point
Re: gun barrel
Are you sure you will be able to produce enough cubic inches of air to launch the ball?
Unread 06-01-2014, 14:03
FRC #3840
Re: gun barrel
it dose not have to be air tite because it is not a air canon
it is just a barrel
Whippet's Avatar
MIT Class of 2020
AKA: Luis Trueba
Re: gun barrel
Well, then, have you looked for circular ventilation ducts in that size?
Unread 06-01-2014, 14:07
FRC #3840
Re: gun barrel
just looked nothing in that size I can find
Unread 06-01-2014, 14:46
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Jibri Wright will become famous soon enough
Re: gun barrel
If it doesn't have to be airtight than why not just make one?
You know someone likes something when after doing it a million times, they still marvel at it as if it was the FIRST.
Greatness asks how can I make it better. Genius asks how can I make it different.
Unread 06-01-2014, 15:05
ChrisArmour ChrisArmour is offline
FRC #3133
ChrisArmour is an unknown quantity at this point
Re: gun barrel
not sure if the material matters but maybe look around for concrete forming tubes, quick search shows that sonoco makes them in 26in if you can find a place that sells them
http://www.sonotube.com/products/son...sizechart.aspx
Unread 06-01-2014, 15:56
Speeder Speeder is offline
AKA: Mr. Don
FRC #0316 (LuNaTeCs)
Speeder will become famous soon enough
Re: gun barrel
Form it from block wire fence.
Unread 06-01-2014, 15:57
FRC #3840
Re: gun barrel
thanks
Unread 06-01-2014, 15:58
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: gun barrel
A piece of material, say 1/16 lexan, cut at 82.68 long and rolled into a cylinder, with a 1 inch overlap (for fastening together) will give you a cylinder with about a 26 inch ID.
Unread 06-01-2014, 16:02
mechlectrician7's Avatar
mechlectrician7 mechlectrician7 is offline
FRC #0894 (Powers 894)
Team Role: Electrical
mechlectrician7 is an unknown quantity at this point
Re: gun barrel
Take your 60 gallon barrel and cut it down one side, take what ever amount you need out of the side then weld the two back together again (assuming you have a welder to use)
Unread 06-01-2014, 22:04
FRC #3840
Re: gun barrel
very good ideas. I would want to use a plastic barrel so I would have to solvent weld weld it and I don't have the equipment.
I like the lexan idea I had thought something like it earlier with plexiglass but plexiglass is too rigid and the overlap would be a problem. I like that concrete forming pipe idea the best. any other ideas
Unread 06-01-2014, 22:32
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: gun barrel
Pardon the insouciance - my first thought on reading the thread intro was "now there's a REAL job for a 3D printer!"
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 06-01-2014, 23:37
FRC #3840
Re: gun barrel
that would be cool if you had a huge printer
