Go to Post You're part of what makes FIRST so special. - Matt Krass [more]
Unread 06-01-2014, 21:01
Riverdance's Avatar
Riverdance Riverdance is offline
AKA: Beth
FRC #5686 (Wirecats)
Riverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud ofRiverdance has much to be proud of
Re: Leftover Autonomous Balls?
Each robot gets a ball to start autonomous, unless a team chooses to start their robot in the goalie zone. In that case, they can either choose to place their ball on the field where an alliance partner can reach and score it, or they can choose to have their ball removed for the duration of autonomous.
After autonomous ends, the new cycle does not start until all the balls in play during autonomous have been scored, and no assist bonuses can be earned. Once all autonomous balls have been scored, the human player takes a ball from the pedestal, puts it back in play, and the new cycle and collection of assist points can begin!
Unread 07-01-2014, 07:23
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Rule reference...
G5
For ROBOTS starting in the white ZONE, the TEAM may preload one (1) of their ALLIANCE’s BALLS such that the BALL is touching their ROBOT.
For ROBOTS starting in their GOALIE ZONE the TEAM may decide if the BALL is: staged between the TRUSS and the ZONE LINE and not contacting an ALLIANCE partner, or removed from the FIELD for the MATCH.
If a ROBOT does not report to a MATCH, its ALLIANCE may decide if the BALL is: staged between the TRUSS and the ZONE LINE and not contacting an ALLIANCE partner, or removed from the FIELD for the MATCH.
Violation: If the situation is not corrected before the start of the MATCH, TECHNICAL FOUL per BALL improperly staged.
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 07-01-2014, 09:25
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
It looks like the commencement of cycles for one alliance is independent of the other. That is, when all the red auto-balls have been scored the red cycles begin even if the blue ones are still bouncing around. Since the assist scores for an alliance cannot commence until cycling, the moral seems to be don't place an auto-ball for your robot, unless you're pretty sure you can score it during auto itself or very soon after. The longer an alliance has to get credits for assist scoring the better.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 07-01-2014, 12:30
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Although 3.1.2 is vaguely worded, I think the intent is per alliance rather than all balls. The sentence starts by referring to alliance (singular) & up to 3 balls.
Unread 07-01-2014, 12:38
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Interesting thought here. I noticed that G5 says "For ROBOTS starting in the white ZONE, the TEAM may preload one (1) of their ALLIANCE’s BALLS such that the BALL is touching their ROBOT." Is this improperly worded, or do you think that this means that you can opt to be in the white zone so you can still get the 5 points but not preload a ball?
EDIT: 5 points for driving to the goalie zone, if that wasn't obvious.
Unread 07-01-2014, 12:54
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
"May" implies that it isn't mandatory, but that might be because I play a bit too much Magic: the Gathering.
Unread 07-01-2014, 14:34
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
I'm still unclear about whether balls left over from autonomous get any points at all if put into a goal at the start of teleop.
The second paragraph of 3.1.4 states that points are awarded once per CYCLE but then table 3-2 distinguishes the base points for a GOAL with the 1-ASSIST point value. Since assists only exist in a CYCLE and there is a minimum of 1 per legal goal, the base point can reasonable be inferred as the point value for a pre-CYCLE ball scored during teleop.
Off to the Q&A...
Unread 07-01-2014, 15:41
Qcom's Avatar
Qcom Qcom is offline
Gearhead
AKA: Quentin
FRC #2996 (Cougars Gone Wired)
Qcom is on a distinguished road
Off to the Q&A...
3.1.2 MATCH Logistics
Although an ALLIANCE may start a MATCH with up to three (3) BALLS, the PEDESTAL will only be illuminated when the last BALL that started the MATCH is SCORED, effectively reducing the number of BALLS in play per ALLIANCE to one (1).
It says in this section (posted earlier by another user) that the balls must be SCORED before another can be added. As it specifies that these balls are SCORED, I think you do in fact get points.
"The systems... They DON'T INTEGRATE!"
Unread 07-01-2014, 16:24
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Today's team update answers this question clearly:
For BALLS with which the ALLIANCE started the MATCH, points are awarded when they are SCORED in GOALS.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 07-01-2014, 17:02
Gemmendorfer Gemmendorfer is offline
That essay was...weird
AKA: Gary
FRC #4183 (Bit Buckets)
Gemmendorfer is an unknown quantity at this point
(Sorry if I missed something in the rules or in another thread, but...) Does this mean that if a Robot A starts with a ball inside them for autonomous but is not functioning at all (Robot A never moves throughout the match) (Similar to Team 1717 in the tournament on Newton and Team 118 on Einstein in 2012), the entire alliance is screwed over/can't score anymore points due to the ball trapped in Robot A? (Or can the alliance start cycling from the pedestal if it is obvious Robot A is dead/disabled and there is no way the ball can be dislodged from Robot A?)
Unread 07-01-2014, 17:15
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Read the first full sentence of today's update.
Spoiler for Update Summary:
The GDC is aware of the confusion, but needs more time to come up with a (potential) refinement to the CYCLE process.
Unread 08-01-2014, 16:58
AKA: Gary
Sorry about that, forgot to check yesterday morning
Unread 08-01-2014, 11:55
AKA: Michael Shires
FRC #0384 (Sparky)
I think that would be a great q&a question, but i would imagine that so long as a team presses their emergency stop any ball possessed by them will be out of play.
Unread 08-01-2014, 17:11
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
I would disagree with you on that statement, but would loved to be proved wrong.
Unread 07-01-2014, 17:46
MikeE's Avatar
no team (Volunteer)
That was a quick and authoritative clarification to my question!
