Go to Post Our opponents didn't know where our robot was going and neither did we! - ReapersRule [more]
Unread 06-01-2014, 21:18
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Running Smartdashboard without cRIO/robot?
If you use the new Smartdashboard (sfx) then you can just write/use a test data source. The built in one just generates sine waves and can be found under Add (+) > Data Sources (the red & gree arrow) and in the top left add a new Test data source, then in the top right save. If you want to do something more complex, the source is here: https://bitbucket.org/byteit101/sfxl...ava?at=default
Watchdog.Kill();
Unread 06-01-2014, 21:31
charr charr is offline
FRC #3504
charr is an unknown quantity at this point
Originally Posted by krieck View Post
> Where can I get the 2014 beta?
For anyone who is impatient, you might run through the installation procedure and set up the latest Java, NetBeans, and the NetBeans plugins: http://wpilib.screenstepslive.com/s/...elopment-tools
The "Release" versions of the WPI plugins have had some updates in the past week, so these may be pretty close to the latest code.
I didn't see any info on downloading the new smart dashboard. Could you provide the specific link?
Unread 06-01-2014, 22:06
If you followed the instructions on that page, the dashboard was downloaded. Instructions for running it are here: http://wpilib.screenstepslive.com/s/...tdashboard-sfx
Unread 06-01-2014, 22:23
FRC #3504
Indeed it is! Sorry, I missed it in the first reading. Thanks.
