Go to Post Remember. There is no controls team, no mechanical team, and no business team without The Team. - Tom Line [more]
Unread 06-01-2014, 17:12
heisenburger heisenburger is offline
FRC #4716
heisenburger is an unknown quantity at this point
Mecanum wheels
Hi, I was just wondering what is the purpose of the mecanum wheels, how do they work and are they worth the $400 for the set of 4, also if the sell them somewhere else cheaper than that could you give me the link?
Unread 06-01-2014, 17:15
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
Re: Mecanum wheels
Mecanums have some nice maneuverability. They are able to strafe, for example. (you can find some videos of it on YouTube)
However, mecanum wheels will be weak for pushing power and can slide around.
You'll likely be pushed around a lot on the field if you use them
Unread 06-01-2014, 17:17
atucker4072's Avatar
atucker4072 atucker4072 is offline
Andrew Tucker
AKA: Andrew Tucker
FTC #4968 (Rapid Robotics)
atucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura about
Re: Mecanum wheels
Where have you looked?
Also make sure you know what size you need. Don't use mecanum wheels just for a cool factor. Mecanum wheels are great for maneuverability, but when it comes to pushing they are worthless.
Unread 06-01-2014, 17:29
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
Re: Mecanum wheels
My team used mecanums last year and they worked well for sliding into place at the feeder station. However, they were terrible when we tried to cycle and were pushed extremely easily. This year may not be the best for mecanums simply because of the lack of safe zones - you can be pushed at any time with nowhere to retreat.
The choice is completely dependent on your team's strategy. Is your shooter reliant on consistent positioning? If so, you may not want to use mecanums because of the pushing issue.
Unread 06-01-2014, 18:21
azcalg's Avatar
azcalg azcalg is offline
FRC #1212 (Sentinels)
azcalg is a jewel in the roughazcalg is a jewel in the roughazcalg is a jewel in the roughazcalg is a jewel in the rough
Re: Mecanum wheels
In this game the only big advantage I see for them is with catching the ball from the truss, so unless that's a big part of your strategy, I wouldn't get them. Another downside to them is that they're quite heavy.
Unread 06-01-2014, 18:23
brennanvhoek brennanvhoek is offline
AKA: Brennan VandenHoek
FRC #1425 (Error Code Xero)
brennanvhoek is on a distinguished road
Re: Mecanum wheels
Mecanum work well if they fit your game strategy. You can get a full set for much less then $400. Vex pro sells a set of 6" for 159.99 http://www.vexrobotics.com/vexpro/wh...um-wheels.html
Also, in my experience the vex wheels preform much better then the andymark equivalent.
Unread 06-01-2014, 18:29
jbsmithtx's Avatar
jbsmithtx jbsmithtx is offline
FIRST Fanatic
AKA: Josh Smith
FRC #4206 (RoboVikes)
jbsmithtx is a jewel in the roughjbsmithtx is a jewel in the roughjbsmithtx is a jewel in the rough
Re: Mecanum wheels
Try VEXpro. They have very affordable yet durable mecanum wheels. The other posters are correct in assuming that unless you are trying to catch, mecanums might not work well this year... However don't believe they are easy to push. We had to play defense with our mecanums last year in matches when our shooter failed and were fine. We could block lots of teams. I know this is contrary to popular belief, but a properly done mecanum drive base can in fact be very strong.
For anyone that wants to question our pushing abilites, we have video...
Unread 06-01-2014, 18:33
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: Mecanum wheels
Mecanum wheels, neglecting friction in the rollers, have an effective coefficient of friction that is a factor of sqrt(2)/2 reduced from that of a traction wheel made of the same material. You can verify this yourself by drawing a free-body diagram of a set of mecanum rollers in contact with the ground.
Whether or not this translates to "being pushed all over the field" depends critically on context (robot weight, weight/drive of opposing robot, weight distribution, manner in which you're hit, etc).
"The breakfast of champions!"
Unread 06-01-2014, 18:35
math311's Avatar
math311 math311 is offline
FRC #2077 (LaserBots)
math311 is an unknown quantity at this point
Re: Mecanum wheels
My team has used mecanum wheels for the last three competitions, and each time we had great success with our drivetrain.
The system is meant to give a robot high levels of maneuverability, and when it is allowed to move at high speed, it creates a formidable opponent. Having the range of motion provided by a mecanum drive can allow a driver to jump out of the way of onrushing defenders, all while maintaining a scoring opportunity
When discussing pushing and mecanum, it should not be forgotten that the goal of this drivetrain is maneuverability, not brute strength. Due to this, a pushing match with a robot designed for pushing will be lopsided. But that does not mean that this drivetrain is easy to push. I have seen our past mecanum drives stop six wheel drives dead, and win pushing matches. When we use mecanum, we maintain a balance of speed and pushing power, and ensure we are not compromising one for the other.
This quote sums the entire discussion up, and is good food for thought. "Mecanum drivetrains, like every other, have advantages and disadvantages" - Mr. B
2008 Wisconsin Regional Judges Award Winner
2010 Wisconsin Regional Delphi "Driving Tomorrows Technology" Award Winner
2013 Wisconsin Regional Quarter Finalist
Unread 06-01-2014, 21:19
Random42 Random42 is offline
FRC #4533
Random42 is an unknown quantity at this point
Re: Mecanum wheels
I have a quick question about mecanum wheels. Can they be placed in a trapezoidal configuration?
Has anyone tried this before? How well does it work?
Unread 06-01-2014, 21:32
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: Mecanum wheels
Could you describe the configuration you are thinking of? Do you mean something like this:
where the [] are wheels and you have the front wheels in narrower (or the back wheels)?
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 06-01-2014, 21:37
Keegbot's Avatar
Keegbot Keegbot is offline
AKA: Keegan McCrary
FRC #2438 (Beta Blues)
Keegbot is an unknown quantity at this point
Re: Mecanum wheels
Our team used the VEXpro wheels last year, and I was very pleased with them. They lasted 2 competitions and multiple fundraisers until they started to fall apart. They are also quiet and light compared to the Andy Mark versions we have used in the past. We also had to be purely defensive in one competition and managed to place high because our mecanum drive allowed us to out-maneuver our opponents and get in front of them to block their shots.
Unread 06-01-2014, 22:03
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Re: Mecanum wheels
I encourage anyone and everyone who thinks that they understand mecanum physics to read the whitepaper given here: http://www.chiefdelphi.com/media/papers/2759?
Unread 06-01-2014, 23:01
FRC #4533
Re: Mecanum wheels
Yes. Something very similar to this. The back wheels would be about 12in apart and the front about 24in apart. The front and back wheels would be about 30in apart.
BEN35678's Avatar
BEN35678 BEN35678 is offline
FRC #1523 (MARS)
BEN35678 is an unknown quantity at this point
Re: Mecanum wheels
Last year we used Andymark mecanum and this year we were looking at the vex pro mecanums, and a couple of our main mentors were worried about them cracking because they are plastic. Did you have anything that looked like it was about to crack or anything like that?
