Go to Post Thanks and don't stay up all night waiting for Lavery Claus! - Beth Sweet [more]
Unread 06-01-2014, 21:19
mechlectrician7's Avatar
mechlectrician7 mechlectrician7 is offline
FRC #0894 (Powers 894)
Team Role: Electrical
mechlectrician7 is an unknown quantity at this point
LED's
So for our driver station, we're thiking of throwing some lights on it. Someone found a couple 7 color LED's that are supposed to alternate through the colors. The only problem is the LED has three leads (short on one side, long on middle, and another short on the other side) and we have only done LED's with 2 leads. So we are at a loss how how to correctly wire is. Obviously this isn't that important and we won't be needing it for a while but any advice or information would be helpful and appreciated. Thank You.
Unread 06-01-2014, 21:23
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Re: LED's
Alright, so basically those LEDs are actually two LEDS in one enclosure, each a separate color. The long lead is the positive lead for both; the short leads are negative and pulsed through the use of something like an arduino in order to control the brightness of each color. Using different combinations of brightnesses, you can create different colors with the LEDs.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 06-01-2014, 21:29
ILAMtitan ILAMtitan is offline
Texas Instruments
AKA: Bart Basile
FRC #3005 (RoboChargers)
ILAMtitan will become famous soon enoughILAMtitan will become famous soon enough
Re: LED's
It's more likely one of these: https://www.radioshack.com/product/i...ductId=3060680
There is a decent document on using them here: http://www.seanliming.com/Docs/Artic..._Color_LED.pdf
Essentially you power them like a normal LED, and then ground the mode pin to cycle it.
Unread 06-01-2014, 21:35
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Re: LED's
Honestly I feel like this should be prohibited.
R8 ROBOT parts shall not be made from hazardous materials, be unsafe, cause an unsafe condition, or interfere with the operation of other ROBOTS.
C. Any devices or decorations specifically intended to jam or interfere with the remote sensing capabilities of another ROBOT, including vision systems, acoustic range finders, sonars, infrared proximity detectors, etc. (e.g. including imagery on your ROBOT that, to a reasonably astute observer, mimics the VISION TARGET)
Because you will be behind the opposite team's goals with leds, it may throw off their targeting of the hot goals, if I'm imagining your LEDS placed up behind the glass. But driver's stations components are not robot parts. The rules specify nothing having to do with driver station LED's, so I guess you'll be okay?. I don't believe I've ever seen it before though. Maybe I'm imagining this wrong? But if not, this could be part of an amazing strategy.
Re: LED's
Is this the LED you bought? http://www.seanliming.com/Docs/Artic..._Color_LED.pdf
Unread 06-01-2014, 21:47
Re: LED's
Oh no, this is just because in past years our driver station has been vey basic, just looking to make it different this year. I did not think about it being a distraction though....so maybe we won't do this...but this is just a thought, probably won't end up happening anyway.
Unread 06-01-2014, 21:48
Re: LED's
Originally Posted by Joe Ross View Post
We got ours from radioshack, but it appears to be practically identical thanks for the link.
Unread 06-01-2014, 21:55
sarah_storer's Avatar
sarah_storer sarah_storer is offline
Georgia Tech RoboJackets Outreach
AKA: Sarah Storer
FRC #5332 (Toaster Tech)
sarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to beholdsarah_storer is a splendid one to behold
Re: LED's
Not sure if you knew this or not, but robots target the hot goal using the same retro-reflective tape from last year. The bright light has nothing to do with it..it is easily tuned out by adjusting settings and parameters in the code.
TEAM 3753 BULAH BOTS ALUMNI
2012-2015: Code, pneumatics, and electrical for BULAH BOTS Team 3753
2013: Bayou Regional 1st seed alliance captain and regional winners (With 118 and 4589)
2014, 2015: Bayou Regional semi-finalist
2016-?: Mentor for TOASTER TECH Team 5332
2016: Columbus District 3rd seed alliance captain, semi-finalist; Kennesaw District 3rd seed alliance 1st pick, semi-finalist; Peachtree District State Championship 4th seed alliance captain, quarter-finalist, Industrial Design Award, World Championship qualification
Unread 06-01-2014, 21:57
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: LED's
In past years I asked officially about using a reasonable brightness light source in the driver's station as a reference point for a robot vision system and perhaps getting other people on your side of the field to place said battery (standard alkaline batteries) powered lights in their windows. There was no major objection.
As long as it's not obnoxious or specifically designed to cause interference it's not really worse than the lights anyone in the audience can walk in with on cameras or the venue lights which might be colored as well.
When it comes to vision systems there ought to be some expectation that you'll encounter some dubious situations.
