Go to Post "Take a man to a FIRST contest and he's entertained for three days. Teach a man to build a FIRST robot, and he's out of your hair for six weeks a year..." - kmcclary [more]
Unread 06-01-2014, 22:34
mechlectrician7's Avatar
mechlectrician7 mechlectrician7 is offline
FRC #0894 (Powers 894)
Team Role: Electrical
mechlectrician7 is an unknown quantity at this point
sealing leaks
Ok so our team uses pneumatics quite often and as im sure most teams have a similar problem, we always have a problem with leaks. The majority of our fittings are fairly new so we know its not that. And we use teflon tape(sp?) but that doesnt always do the trick, just wondering if anyone has any other tricks or products that do a better job?
Unread 06-01-2014, 22:42
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: sealing leaks
The easiest way is to prevent leaks in the first place.
If you are using the plastic storage tanks, don't tighten the fittings too much, leave a thread or two visible. It is very easy to crack them.
Cut all of your tubing square on the end so that it fits in nice and snugly.
Make sure all of your tubing is fully plugged in.
Be liberal with teflon tape but don't overdue it. 2 or 3 wraps around the threading should be fine. Be careful that you are wrapping it the correct way as well. Counterclockwise I believe (someone correct me right away if I'm wrong).
Make sure that all of your components are nice and tight. Use a wrench, don't just hand tighten.
If you do have leaks, apply soap water to your pneumatics and look for the bubbles. That should show the problem region and then just check everything in that area for the above mentioned problems. Good luck!
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 06-01-2014, 22:47
Big Ideas Big Ideas is offline
AKA: Stephen des Jardins
FRC #2102 (Team Paradox)
Big Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant futureBig Ideas has a brilliant future
Re: sealing leaks
Are the leaks at the threaded joints, or elsewhere?
For pipe thread joints:
5 wraps of PTFE tape and 3/4+ turns after finger tight. Make sure that the first thread is not taped and that there is no tape on the front face of the male fitting. Clean off old tape and re-tape if the fitting is being reused. PTFE tape does not seal well if reused.
If the leaks are out of the "One Touch" style tube fittings--The NUMBER 1 OFFENDER is the tube ends NOT being cut square. If tubes are cut at a slant, or not cut cleanly, the o-ring seals at the bottom of the fittings will not make a good seal all around the tube.
Unread 06-01-2014, 22:56
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: sealing leaks
It only takes one or maybe two wraps of tape on a threaded fitting to seal it, if you tighten the fitting properly.
Make sure the end of the tubing is cut square, and make sure it's pushed in all the way. If the tubing has been used for a while, you might need to cut off the end again and re insert it.
Unread 06-01-2014, 23:12
Re: sealing leaks
Helps a lot, thank you!
Unread 07-01-2014, 00:21
donkehote's Avatar
donkehote donkehote is offline
Design/Manufacture/Strategy Mentor
AKA: Kevin
FRC #5031
donkehote is just really nicedonkehote is just really nicedonkehote is just really nicedonkehote is just really nice
Re: sealing leaks
If you have major leak issues, or students who are overzealous with teflon tape, you can use pipe sealant. Its much more forgiving and lass prone to develop leaks, at least in my experience.
You dont have to get the loctite brand, other brands work too, i know Brafasco carries it, possibly hardware stores as well.
Unread 07-01-2014, 07:51
Re: sealing leaks
Use liquid with discretion, too much will pass into the cylinder and/or needle valve if you are using one. Tape has worked for us for many years. It isn't rocket science to wrap a few turns and tighten the fitting. Almost always, leaks occur at tubing that is not cut square or pushed fully into the fitting. A tubing cutter from McMaster or other source is worth every penny.
Unread 07-01-2014, 07:54
MrForbes's Avatar
AKA: Jim
Re: sealing leaks
As Al says, it's not really difficult. I'd guess that 98% of the pneumatic leaks we get are a result of the tube not being pushed all the way into the fitting.
It's easy to check that...just firmly push in all the tubes, and see if the leaks stop.
Make sure the tubes are long enough, if they are bent to tightly, they will tend to leak, because they can't sit straight in the fitting. If necessary, replace with a longer piece of tubing.
