Go to Post I hope we as a team can learn the value of doing less but doing it incredibly well. - Rob Stehlik [more]
Unread 07-01-2014, 12:27
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Re: Launching the ball
Not sure what "blocking the cylinder" actually is, but to have most of the air ahead of the retracted piston be gone when you want to fire the piston with max. peak velocity, you either need to evacuate it with a vacuum pump, or seal the exhaust port when the piston is full extended and then pull the piston back into the cylinder, creating a vacuum inside the cylinder as it retracts.
This demands some kind of retraction mechanism combined with a trigger hold/release mechanism strong enough to retain the piston with 120 psi behind it. Venting pressure during retraction and reapplying it after retraction allows for the retraction mechanism to be weaker. The key factor is to have a cycle that maintains as little air in the cylinder as possible when piston is retracted and ready to fire.
Having to push out almost no air from the cylinder, ahead of the piston disk as it accelerates gives a serious boost to peak velocity, and lengthens time in contact with the ball.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
