Go to Post 71% efficiency is best efficiency. ;) - Chris is me [more]
Unread 07-01-2014, 12:24
andre_ribeiro97's Avatar
andre_ribeiro97 andre_ribeiro97 is offline
AKA: "Doc"
FRC #2191 (Flux Core)
Team Role: CAD
andre_ribeiro97 is an unknown quantity at this point
How legal are tension springs?
We were thinking that tension springs would put more force out per inch of movement than surgical or latex tubing. After searching the rules multiple times and checking the list of legal and illegal parts, tension springs are not mentioned. In order for our initial shooter idea to work in the least amount of space, however, we need to use them. Anybody know if they're legal, or if theres another springy material that would work just as well?
Thank you on behalf of Team 2191 Flux Core.
Unread 07-01-2014, 12:36
Aur0r4's Avatar
Aur0r4 Aur0r4 is offline
Engineering Mentor
AKA: Jim Browne
None #1058 (PVC Pirates)
Aur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant future
Send a message via AIM to Aur0r4
Re: How legal are tension springs?
I believe they are definitely legal IF they are slack when the robot goes on the field and/or is disabled. The stored energy rule is designed to prevent a robot from being handled while significant amounts of energy are stored in components creating an obvious safety hazard.
Jim Browne, EIT
Team 1058 - PVC Pirates
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Tension springs are legal. It up to you to properly apply them. The robot inspector can decide that the design utilizing springs is unsafe. Unsafe can be springs, exposed propeller blades, exposed shooter wheels, ETC.
[T12] refers to springs on the robot.
[R34] Non-electrical sources of energy used by the ROBOT, (i.e., stored at the start of a MATCH), shall come only from the following sources:
A. compressed air stored in the pneumatic system that is legal per R79 and R80,
B. a change in the altitude of the ROBOT center of gravity,and
C. storage achieved by deformation of ROBOT parts.
[R34-C] is commonly known as a spring. It can be compressed/tensioned at the start of the match.
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
If there is no rule against them, then they are legal. (There is none).
Keep in mind, however, that surgical tubing can provide as much force as you need it to - just keep adding bands of surgical tubing. That is why it is so wonderful to work with. If you want to used springs over tubing, then I'd prototype with tubing to find a rough spring force constant and verify it with a little math. Otherwise you'll be spending a lot of money on springs.
Unread 07-01-2014, 12:38
Chris is me's Avatar
AKA: Pinecone
Tension springs are specifically permitted as an energy source on the robot - energy from "deformation of robot parts" refers to surgical tubing, springs, etc.
Unread 07-01-2014, 12:41
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
I don't think that tension springs are necessary. Surgical tubing is essentially the same thing, but with a feel-good squishiness that will make your life better. Plus, it's free in the KOP!
We did a quickie catapult test yesterday using two loops of surgical tubing stretched 2 feet. It launched the ball with about 4 feet of loft. By doubling up the tubing, we should be able to get the necessary height on our next try.
--David Forbes
Mentor, Bit Buckets team 4183. Assistant cat herder and dispenser of legendary tales.
Need a Nixie watch? Yes, you do. Ask me.
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
If it's not mentioned, it is probably legal. In this case:
B. a change in the altitude of the ROBOT center of gravity, and
(Emphasis mine.)
So yes, you can use a spring.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 07-01-2014, 12:43
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Pro safety tip: put a string through coil springs that is tied off securely on the robot frame. This will help prevent the spring from jumping out and killing an inspector if it snaps.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 07-01-2014, 12:44
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Surgical tubing is certainly workable; however, you will find that over time it will degrade in performance and you will have to tighten it or replace it. Probably fine for one regional, but an actual spring will remain much more consistent over time.
Mentor 2415
Unread 07-01-2014, 12:57
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
my team 1108 was one of the few that built a catapult for rebound rumble in 2008 and we started and ended with coiled steel springs running it. We made surgical-tubing springs and tried them for a while but they stretch over time, they oxidize and where they're fastened, they tear. Steel springs had no degradation. I think we were able to get more energy into a smaller space too.
At first when we installed the coils, we thought they would require a cable down the middle like on your garage door, but no one ever mentioned it.
Note that one of the 'bots' on the game-introduction video visibly has a compression spring catapult.
I think we'll end up with metal springs again, but I can't say that for sure now. Also, air springs a possibility.
