Go to Post Clearly they're releasing the game hint on 12/21/12 because they know the world's going to end, and they want to keep FIRSTers happy and distracted until the very end. - Kevin Sevcik [more]
Unread 07-01-2014, 12:56
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Re: Mecanum vs Omni vs KOP wheels
Originally Posted by Keegbot View Post
The reason I'm in favor of mecanum is to catch the ball because it will allow you to maneuver to the ball easier than tank would. It will also help you chase down balls faster if your alliance partner is an inaccurate passer than tank would.
Imagine playing Rebound Rumble with the goals moving. It's way harder. A catcher should be stationary, make it easy for your thrower to hit you. There should be no trouble making a very consistent ball-launcher.
Sure, you may be able to adjust to catch a ball on your practice field, but when you get pushed across the field for 2:20 you won't be a very effective catcher.
