Re: Running a VMware Player Virtual Machine to run a Driver Station
You should make sure that you uninstall the driverstation from the host computer so that it doesn't cause IP conflicts if opened.
The driverstation has an option to modify your IP address automatically by default to change it to the 10.TE.AM.5 IP address required. Doing this on the host and VM computer will cause conflicts. Also I would recommend only using the VM Driver Station for testing purposes only, and not as your competition driver station. You should have a dedicated driver station propoerly configured to run natively on the hardware for competition and matches. |
Some things to watch out for:
I work primarily with ESX and ESXi, so I don't know if workstation has this, but ensure USB passthrough is enabled, so the Virtual can access the controllers. If you use bridging, the field may authenticate the traffic packet based on MAC address, and if the VM interface MAC is encapsulated in the payload, but the Physical MAC's interface is registered as sending the packet, the field radio could reject/drop those packets. I think this is highly unlikely, as the field network last year was a simple configuration. The same applies if you are using NAT'ting, except replace everywhere I said MAC with IP address. Because different organizations have produces all of these different items at a nearly free to FIRST level, I HIGHLY doubt this is integrated in to the Field. Those are the big ones I can really think of. Make sure you have vmtools installed so as to optimize your video, and virtual hardware to hardware mapping. Hope this helps, and let me know if you have nay other questions. D |
I don't think the field network configuration is as simple as you suspect. From the FMS whitepaper: Quote:
What is being discussed in that body of text refers to creating multiple isolated Virtual Local Area Networks (VLANs) in order to keep traffic communications privatized per network (or robot in this case). This could prevent someone on one robot from spoofing traffic on another robot on the opposing team. If you're statement that bridging did not work, then yes, there could be another method of security in play. I would have to see the traffic to determine if that is the case and what it may be. 0] Thanks for the info! I appreciate it. It will be interesting to see their latest whitepaper. I'm sure I'll be asking more questions. D |
