Go to Post Let this be a hint to the hardware teams. Deliver that robot early and give the software and driving team time with the robot. IR3 has proven it can be done. - Doug Leppard [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 07-01-2014, 15:51
mistersands mistersands is offline
FRC #4528 (Automatons)
mistersands has a spectacular aura aboutmistersands has a spectacular aura aboutmistersands has a spectacular aura about
300 point cube 3d printer?
It seems this one isn't very popular. We are finding ourselves with a lot of points and not much left to choose from because we missed the second first choice. Is this one worth spending 300 points on or should we just not bother? We probably won't use it this year. I don't have any idea how we would. But I'm not sure what else to get from what's left with my 450 points.
Unread 07-01-2014, 16:03
mechanical_robot's Avatar
mechanical_robot mechanical_robot is offline
Team Role: Driver
mechanical_robot will become famous soon enough
Re: 300 point cube 3d printer?
Well it can print out I think a 5x5x5 cube is it's maximum size of a object it can print out. We won the Cube 3D printer. It is a plug in play printer meaning you can pretty much use it as soon as you plug into it. No assembly required really except registering the product with CUBE. You could use it for your robot or if you guys want to create something unique instead of shirt button to give out at competitions it would be perfect.
Unread 07-01-2014, 16:12
JeffersonMartin's Avatar
JeffersonMartin JeffersonMartin is offline
FRC #1648 (G3 Robotics)
JeffersonMartin has a spectacular aura aboutJeffersonMartin has a spectacular aura aboutJeffersonMartin has a spectacular aura about
The main problem with the cube printer is that it requires a proprietary filament cartridge that is significantly more expensive than normal. You can bypass it with something like http://www.makergeeks.com/cu3dprfiad.html so that you can use cheaper filament, but that is spotty as far as I understand. If there is nothing else your team wants out of FIRST choice, then go fr it, but consider what your getting yourself into.
"Learn to love work."
Unread 07-01-2014, 16:27
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
It's not necessarily that this one is less popular than the other 2 printers (though that may be the case). There were 347 of these printers available and only 49 MakerBots and 49 replicators.
FIRST also reduced the credit cost of the printers late last weeks so not all teams may have even been aware that it's 300 pts rather than the original 600.
We ran into the same issue of not having more than 150 pts worth of stuff we wanted, so we ended up getting the Cube, as the others were already sold out.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 07-01-2014, 21:22
DonRotolo's Avatar
Back to humble
FRC #0832
Ditto. We are a 2 school district, and the 'other' school already has a 3D printer, but faced with 450 credits and not much we really needed, the Cube was the way to go.
Yes, the filament is relatively costly. The school is unlikely to go for the hack. So, they'll buy 6 cartridges a year, and be happy, because the 3D printing class can be expanded to the seocnd school earlier than planned.
The Cube is definitely the most plug-n-play of those offered. Good for a school...
Unread 08-01-2014, 15:21
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
We got our cube and did a test print. It worked out of the box and fairly useful if we need to a test design quickly.
Here is a picture of a modified VEX 60 tooth gear we printed this week.
http://www.thingiverse.com/make:61269
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 08-01-2014, 17:25
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
did you use Cubify Sculpt
for design or some other programs
TEAM 1946-Tamra
Unread 07-11-2014, 14:14
Certified Nerd's Avatar
Certified Nerd Certified Nerd is offline
The Only Certified Nerd! GOT IT?!
AKA: Danny
FRC #3840 (TNT)
Certified Nerd is an unknown quantity at this point
You mean 49 replicators and 49 M2s?
Unread 07-11-2014, 16:59
MechEng83's Avatar
AKA: Mr. Cool
Aside from the irrelevant thread necromancy, yes, I meant the MakerGear M2. You can check the first choice beta site for the time being to see what the options were. http://firstchoicebyandymark.com/3d-printing?orderby=11
Red Alert Robotics
Unread 08-11-2014, 14:57
yara92's Avatar
AKA: Mohamed
This store is currently closed
TEAM 1946-Tamra
Unread 08-11-2014, 15:36
Aroki's Avatar
Aroki Aroki is offline
FRC #1787 (Flying Circuits)
Team Role: CAD
Aroki will become famous soon enoughAroki will become famous soon enough
If there's nothing else you want from first choice, why not? But I'd only recommend getting it if there is nothing else that you want to fill the 300 points.
We ended up getting two through first choice last year (first one was broken so Cubify sent us a replacement, before we fixed the first). It worked decently however once we got a grant to buy a Makerbot Replicator 2, both cubes ended up in the back of a storage cabinet.
Unread 08-11-2014, 21:35
adammiller3122's Avatar
adammiller3122 adammiller3122 is online now
FRC and FTC Mentor
AKA: Adam Miller
FRC #3122 (The Alluminators)
adammiller3122 will become famous soon enough
We got one and it is OK. It is not the greatest, but for what we used it for so far, it works fine. (keychains for our giveaway)
Adam Miller
New Ulm Robotics - Alumni
FRC Team 3122: The Alluminators (mentor)
FTC Team 8005: Robot Renegades (mentor)
FTC Team 10493: RoboWarriors (mentor)
homepage: newulmrobotics.com
