Go to Post I like my eyeballs where they are ::safety:: - ,4lex S. [more]
Unread 07-01-2014, 16:52
jee7s jee7s is online now
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Team UPDATE - 2014-01-07
Originally Posted by SM987 View Post
This is somewhat disappointing. A flawless auto now gives you a smaller point advantage (plus a faster cycle start). Takes some emphasis off auto.
How do you figure? You still get the bonuses, right? Just making the high goal and driving forward is worth two goals. And, the less performing you are in Autonomous, the longer it takes to start your first cycle of the match. I don't see how there's that much of a change here.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 07-01-2014, 16:55
JeffersonMartin's Avatar
JeffersonMartin JeffersonMartin is offline
FRC #1648 (G3 Robotics)
JeffersonMartin has a spectacular aura aboutJeffersonMartin has a spectacular aura aboutJeffersonMartin has a spectacular aura about
Originally Posted by Duncan Macdonald View Post
emphasis mine
Perhaps I'm being overly cautious, but I am reading this to effectively say "A ball must land within the alliance station to score" because the alliance station is defined as an area and not a volume (or projection of an area). This would limit the maximum range to get credit for a goal at about 10 feet. (Also increase safety for anyone walking behind the field if you like that kind of thing)
Thoughts?
I don't know if it increases safety. I see this getting a lot more coaches and drivers, who can't really be aware of balls coming in through the goal, hit by scored balls.
"Learn to love work."
Unread 07-01-2014, 16:58
FRC #6357
emphasis mine
Thoughts?
The definition of ALLIANCE STATION is:
The Red and Blue ALLIANCE STATIONS are located at either end of the FIELD, behind the ALLIANCE WALLS. The ALLIANCE STATION extends 10 ft. back from the ALLIANCE WALL and 1 ft. 8 in. beyond the carpet on each side. The ALLIANCE STATION includes the three (3) PLAYER STATIONS and one (1) PEDESTAL. The STARTING LINE is marked with white 2 in. wide gaffers tape 2 ft. 6 in. behind the ALLIANCE WALL. The ALLIANCE STATION includes the area up to the entry gates of the FIELD, with the end of the ALLIANCE STATION marked out in 2 in. white gaffers tape.
Since it extends "behind the ALLIANCE WALLS" and the ALLIANCE WALLS are vertical, that means the ALLIANCE STATION is a volume, by my interpretation.
IMHO.
FLL Mentor 2006
FRC 619 Mentor 2002
Unread 07-01-2014, 17:06
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
I'm thinking that
a ROBOT causes one (1) of their ALLIANCE’S BALLS to cross completely through the opening(s) of one (1) of their ALLIANCE’S GOALS and into the opposing ALLIANCE STATION without intervening human contact,
is an addition mostly to clarify that for the low goals, they have to go into the low goal box and through the alliance station wall to be scored, rather than indicating that high goal shots have to land inside the alliance station tape.
Unread 07-01-2014, 17:21
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Originally Posted by vhcook View Post
I'm thinking that
Correct. Previously, the low goal was scored when the ball passed the planes defined by the outer faces of the cubes. It was possible to shoot a ball through the side face of the cube and have it bounce back out, available to be scored again and again. This clarifies that the ball does not score the low goal until it passes through the wall, into the alliance station, where it can be recovered and placed on a pedestal.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 07-01-2014, 18:30
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
The best and most significant part of this update is the one about the Chairman's Video. Thank you, HQ, for making this change.
Hi!
Unread 07-01-2014, 19:09
Bald & Bearded Bald & Bearded is offline
Jack of All Trades/Master on none
FRC #1885 (ILITE Robotics)
Bald & Bearded is on a distinguished road
But now I wonder how hard it would be for a ball to get stuck in one of the low goals. Hopefully someone with access to a real field will provide some information on that. Also, with the fact that the low goal is so close in size to the ball itself plus the 7" lip at the bottom high goals might just be easier to score.
Unread 07-01-2014, 19:50
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
It reduces the point advantage to 15 points from what it was. The faster cycle start is arguably non-existent as well since the missed ball can be retrieved by the best high goal scorer (who will most likely stay in the colored zone anyways) while the other two robots go delay the start of the opponents' first cycle via defense and setup for the start of their own cycles. The only reliable counter to that is a goalie bot, which then puts the 3rd autonomous ball at risk (unless it's a NASA bot...).
GitHub
Unread 07-01-2014, 22:53
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Originally Posted by Team UPDATE - 2014-01-07
TEAMS positioning ROBOTS in the white ZONE have precedence over opponents placing ROBOTS in the GOALIE ZONE.
I'm not sure why they chose the word precedence.
Originally Posted by Precedence Definition
The condition of being considered more important than someone or something else; priority in importance, order, or rank.
I assume this means that a robot positioning itself in the white alliance gets the last move, because it is more important?
What does more important mean, in terms of positioning?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 07-01-2014, 22:54
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Q&A Dartboard Detractor
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I know it's not always great to make direct comparisons, but in 2013, if an alliance took advantage of all discs availalbe on your half of the field, they could score 78 points (the points available at midfield would give an extra 12 points). In 2014, the points an alliance can score in autonomous is 75. It's not that bad.
Unread 07-01-2014, 23:05
Karibou Karibou is online now
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
I believe that answers the question asked in this thread. Makes it a bit harder to block in auton.
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 07-01-2014, 23:34
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
One of the best team updates ever!
If you thought they wouldn't be worth points before, yes I agree that it takes "some" emphasis off of autonomous mode. But there's still a huge emphasis, not the least of which is starting your cycle sooner. Five bonus points for each ball scored (regardless of goal), five points for moving, and a possibly five points further for scoring in a hot goal. That could be 15 points per robot in bonuses alone.
Unread 08-01-2014, 01:16
cbudrecki's Avatar
cbudrecki cbudrecki is offline
AKA: Carl Budrecki (buh-dre'-key)
FRC #0222 (Tigertrons)
cbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to allcbudrecki is a name known to all
disappointed that they didn't really define G4, C - "their GOALIE ZONE". although, the "opponents placing ROBOTS in the GOALIE ZONE" does indirectly clarify it a bit.
Unread 08-01-2014, 02:25
I was thinking the exact same thing.
Unread 08-01-2014, 02:35
DampRobot's Avatar
Physics Major
AKA: Roger Romani
It is a rather confusing word for the situation...
-Plutarch
