Re: CNC Machines
Maybe consider this though https://www.inventables.com/technolo...kit-shapeoko-2 |
Re: CNC Machines
Re: CNC Machines
A full size CNC knee mill can be found from $3k to $10k used.
Re: CNC Machines
So, give me a good example of one I can get for 4000
Re: CNC Machines
I can't give specific examples, as these are used machines (check craigslist, ebay, etc...). A 3000+ lb knee mill with 30-32" of X travel is fairly standard, and lots of companies make them.
We have one from Millport that we just finished upgrading and we love it. |
Re: CNC Machines
We use a Bridgeport 3 series CNC converted to a full CNC with a Centroid CNC kit.
It's a good machine . You could probably find one used for 8000. |
#7
Re: CNC Machines
Hi Colin
look this over, http://www.boltontool.com/metal-lath...hines_880.html we purchased a CNC lathe from Bolton and have had good luck with it, i would have got a miil too but the cash ran out, (they had one for 8K no program) have Fun Geo. |
#8
Re: CNC Machines
Taig CNC tabletop mill, purchased through Nick Carter (google) and stepper/Mach3 package from Dan Mauch
We are using Cut2D for the CAM package I've had mine for 2 years and the team has had theirs for 6 months. It's a tough little machine. You can add a spacer on the y-axis to increase travel to 6.5" For the most part with creative setup you can mill most of your parts. I added a piece of tooling plate with 10-32 holes drilled every 1" to make fixturing easier. We are also using a flood coolant system with Trim E206 fluid which works very well for aluminum Kelly |
