Go to Post This could be interesting...rednecks of FIRST unite for duct tape - amos229 [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 07-01-2014, 21:24
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Legal compressors?
Originally Posted by jee7s View Post
One large fan blowing on the top heatsink goes a long way to keeping that motor cool.
FWIW, it isn't the motor that gets so hot, it is the compressor cylinder (head & piston).
Unread 07-01-2014, 22:03
The Thomas 215 compressor also meets the CFM requirements.
Unread 07-01-2014, 23:19
yash101 yash101 is offline
AKA: null
That makes sense because when you compress gasses (and solids/liquids), each molecule has heat. When there are a ton of molecules in one place, the heat adds up until it is unbelievably high. Entropy takes away most of the heat via the heat sink. However, active cooling is something that can just almost always aid in passive cooling! The motor will typically be a quite efficient one that shouldn't get too hot. The problems start occurring when the motor is so close to the piston that the heat is moved to the [cooler] motor because of entropy. This is similar to what happens in the air conditioner. The gas is compressed, taking away the heat. that way, in the condensor, it is decompressed, leaving you with supercooled gas to cool the air using!
Unread 08-01-2014, 00:14
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
As long the the compressor manufactures used proper high temperature bearings, any heat transfer between the head, piston rod and eccentric bearing is negligible. The failure mode for most compressors is either the cup (part that glides and seals between the piston and the piston sleeve) wearing prematurely due to heat, or the sleeve flaking due to being overheated which damages the cup.
It is worth to note, that with someone who knows what they are doing, these parts are easy to replace.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 08-01-2014, 02:35
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
If you haven't I would take advantage of positioning one of the large papst fans provided in the kit of parts at the top heatsink. It made the difference between near instantaneous burns and being uncomfortable to hold onto for a couple of seconds last year in our pneumatic intensive robot.
It definitely presents a strong case for active cooling, and our compressor was (and still is) reliable for 2 competitions, 2 off-seasons and a build-season scrimmage.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 08-01-2014, 02:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We've gotten them hot enough to melt pneumatic tubing about an inch away from the head, but we've never had one fail, even running the robot almost nonstop for several hours.
Unread 08-01-2014, 09:48
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
i want to say in 2012 the holycows????? ran a car seat one, that inflated a lumbar support.
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 13-01-2014, 17:01
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
We have used these two compressors:
http://www.gd-thomas.com/productlist.aspx?id=10124&tp=p (the Thomas 215 that Joe mentioned)
http://www.gd-thomas.com/productlist.aspx?id=10120&tp=p
2001-2004: Team 100
2006-Present: Team 254
Unread 14-01-2014, 01:20
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
Originally Posted by Cory View Post
Any particular reason for this? Advantages/Disadvantages?
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 14-01-2014, 11:57
Cory's Avatar
AKA: Cory McBride
They are substantially lighter than the previous KOP compressors.
2001-2004: Team 100
Unread 13-01-2014, 17:19
Jon Stratis's Avatar
FRC #2177 (The Robettes)
and doing so would make the compressor illegal for use on a competition robot, per R76: "All pneumatic COMPONENTS must be used in their original, unaltered condition." Repairs are technically alterations, and there's no way for a third party (ie an inspector) to know if you have sufficient knowledge/experience to perform the repairs and result in a functionally equivalent and safe compressor.
2016: Lake Superior WFFA
Unread 14-01-2014, 02:09
Nirvash's Avatar
AKA: Bryan
FRC #4676
Ah, I work with electronics too much and forget that repair rule didn't extend beyond electronics.
Sadly restrictive there, but a rebuild kit is about half the cost of the compressor new, so there isn't too much savings anyway.
Unread 14-01-2014, 07:20
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Be advised if youuse a "non KOP" compressor that meets R79, make sure you bring the manufacturer's data sheet to your competition to prove to the inspector that the 12VDC and 1.05 cfm is not exceeded.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 08-01-2014, 00:13
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Yeah, I know its not the motor. I was typing too fast on that one.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
