Thread Tools |
Rating:
Display Modes |
Re: Legal compressors?
That makes sense because when you compress gasses (and solids/liquids), each molecule has heat. When there are a ton of molecules in one place, the heat adds up until it is unbelievably high. Entropy takes away most of the heat via the heat sink. However, active cooling is something that can just almost always aid in passive cooling! The motor will typically be a quite efficient one that shouldn't get too hot. The problems start occurring when the motor is so close to the piston that the heat is moved to the [cooler] motor because of entropy. This is similar to what happens in the air conditioner. The gas is compressed, taking away the heat. that way, in the condensor, it is decompressed, leaving you with supercooled gas to cool the air using!
It is worth to note, that with someone who knows what they are doing, these parts are easy to replace. |
If you haven't I would take advantage of positioning one of the large papst fans provided in the kit of parts at the top heatsink. It made the difference between near instantaneous burns and being uncomfortable to hold onto for a couple of seconds last year in our pneumatic intensive robot.
It definitely presents a strong case for active cooling, and our compressor was (and still is) reliable for 2 competitions, 2 off-seasons and a build-season scrimmage. Last edited by Trent B : 08-01-2014 at 02:38. |
We've gotten them hot enough to melt pneumatic tubing about an inch away from the head, but we've never had one fail, even running the robot almost nonstop for several hours.
i want to say in 2012 the holycows????? ran a car seat one, that inflated a lumbar support.
We have used these two compressors:
http://www.gd-thomas.com/productlist.aspx?id=10124&tp=p (the Thomas 215 that Joe mentioned) http://www.gd-thomas.com/productlist.aspx?id=10120&tp=p |
#7
They are substantially lighter than the previous KOP compressors.
#9
and doing so would make the compressor illegal for use on a competition robot, per R76: "All pneumatic COMPONENTS must be used in their original, unaltered condition." Repairs are technically alterations, and there's no way for a third party (ie an inspector) to know if you have sufficient knowledge/experience to perform the repairs and result in a functionally equivalent and safe compressor.
#10
Sadly restrictive there, but a rebuild kit is about half the cost of the compressor new, so there isn't too much savings anyway. |
#11
Be advised if youuse a "non KOP" compressor that meets R79, make sure you bring the manufacturer's data sheet to your competition to prove to the inspector that the 12VDC and 1.05 cfm is not exceeded.
