Go to Post You all are brilliant people. - Andy Baker [more]
Unread 08-01-2014, 00:01
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Re: FIRST Button on WindRiver not appearing
Last year we had more problems with this. There are half a dozen threads on chief delphi about the missing FIRST menu but I can't recall what fixed it for us.
I want to say it may have been a 32bit/64bit mismatch.
Are you running 64 bit or 32 bit?
When I setup a new computer today I only did the first disk. No LabView and then installed the update and all was well.
You might try deleting everything again. Run a registry cleaner like CCleaner and then do the install. Or go through the registry searching for Windriver and deleting entires associated with it and do the install again.
I'm sorry I couldn't be more help.
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
