Go to Post Suggesting change is one thing, implementing it is another. - JaneYoung [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 07-01-2014, 15:58
Maine951 Maine951 is offline
AKA: Daniel
FRC #0533 (PSIcotics)
Maine951 is an unknown quantity at this point
Legal compressors?
My team is trying to look away from the small compressor. The am-2005 on andy mark. We have gone through 2 of them last year and 1 in the previous year. We don't want to go to the bigger compressor that has been with first due to the weight of it. Are there other legal compressors we can use? Or is it any compressor as long as it doesnt go over the cfm?
Unread 07-01-2014, 16:04
jee7s jee7s is online now
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Legal compressors?
Per R79:
R79
Compressed air on the ROBOT must be provided by one and only one compressor. Compressor specifications may not exceed nominal 12VDC, 1.05 cfm flow rate.
So, if it's powered by 12VDC with max flow rate of 1.05cfm, you're in business.
But, the better question is why do you have compressor failures? My team has used the same compressor for three years now. It's a Viair...I assume that's what you mean by "small compressor". Are you overheating it? I've run into a couple teams that ran the compressor well past its duty cycle (the Viair Spec says 9% -- yes, that's NINE percent) who ran into trouble. One large fan blowing on the top heatsink goes a long way to keeping that motor cool.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 07-01-2014, 16:05
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I'm curious which one 254 uses. It's similar in appearance and size to the standard small Viar, but distinctly different.
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
R79
Pretty much any compressor that fits that criteria.
Edit: NVM posted while I was posting.
Unread 07-01-2014, 16:07
FRC #6357
Viair has a few options that comply with the rules:
http://www.viaircorp.com/c-models.html
We get the 90C as part of FIRST Choice, my team uses the 92C, and that 95C seems to have a different motor. Perhaps that's the 254 compressor?
FLL Mentor 2006
FRC 619 Mentor 2002
Unread 07-01-2014, 16:09
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
From what I see,
4.10.4 R77
The only pneumatic system items permitted on 2014 FRC ROBOTS include the items listed below.
A. Items available in the 2014 KOP,
J. Compressors compliant with R79.
Which is
4.10.6 R79
So yes, you can use a different compressor, assuming it meets those specs.
However, I am more curious HOW you have gone through three compressors now, while the VIAIR may not be a workhorse of a compressor, it should last a lot longer then that. Are you running your compressors for extended periods of time without active cooling on them (A fan cooling the compressor head)?
(And took too long to post, didn't I?)
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 07-01-2014, 21:24
DonRotolo's Avatar
Back to humble
FRC #0832
FWIW, it isn't the motor that gets so hot, it is the compressor cylinder (head & piston).
Unread 07-01-2014, 22:03
The Thomas 215 compressor also meets the CFM requirements.
Unread 07-01-2014, 23:19
yash101 yash101 is offline
AKA: null
That makes sense because when you compress gasses (and solids/liquids), each molecule has heat. When there are a ton of molecules in one place, the heat adds up until it is unbelievably high. Entropy takes away most of the heat via the heat sink. However, active cooling is something that can just almost always aid in passive cooling! The motor will typically be a quite efficient one that shouldn't get too hot. The problems start occurring when the motor is so close to the piston that the heat is moved to the [cooler] motor because of entropy. This is similar to what happens in the air conditioner. The gas is compressed, taking away the heat. that way, in the condensor, it is decompressed, leaving you with supercooled gas to cool the air using!
Unread 08-01-2014, 00:13
FRC #6357
Yeah, I know its not the motor. I was typing too fast on that one.
FLL Mentor 2006
FRC 619 Mentor 2002
Unread 08-01-2014, 00:14
Nirvash's Avatar
AKA: Bryan
FRC #4676
As long the the compressor manufactures used proper high temperature bearings, any heat transfer between the head, piston rod and eccentric bearing is negligible. The failure mode for most compressors is either the cup (part that glides and seals between the piston and the piston sleeve) wearing prematurely due to heat, or the sleeve flaking due to being overheated which damages the cup.
It is worth to note, that with someone who knows what they are doing, these parts are easy to replace.
Unread 08-01-2014, 02:35
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
If you haven't I would take advantage of positioning one of the large papst fans provided in the kit of parts at the top heatsink. It made the difference between near instantaneous burns and being uncomfortable to hold onto for a couple of seconds last year in our pneumatic intensive robot.
It definitely presents a strong case for active cooling, and our compressor was (and still is) reliable for 2 competitions, 2 off-seasons and a build-season scrimmage.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 08-01-2014, 02:38
We've gotten them hot enough to melt pneumatic tubing about an inch away from the head, but we've never had one fail, even running the robot almost nonstop for several hours.
Unread 08-01-2014, 09:48
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
i want to say in 2012 the holycows????? ran a car seat one, that inflated a lumbar support.
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 13-01-2014, 17:01
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
We have used these two compressors:
http://www.gd-thomas.com/productlist.aspx?id=10124&tp=p (the Thomas 215 that Joe mentioned)
http://www.gd-thomas.com/productlist.aspx?id=10120&tp=p
2001-2004: Team 100
2006-Present: Team 254
