Go to Post No one would climb Mount Everest before climbing the hill in the park down the street. - RbtGal1351 [more]
Go Back   Chief Delphi > Technical > CAD
Unread 08-01-2014, 08:20
WarrenV WarrenV is offline
FRC #1403
WarrenV is an unknown quantity at this point
3D Printing and Inventor
Hello everyone, I've had some problems and I need some help. I am the design leader on my robotics team, and recently we purchased a new 3D Printer, a CubeX Duo to be exact. Now the problem is when we attempt to 3D print a part that we created in AutoDesk Inventor, the part was WAY too small. Instead of printing 1", it printed roughly 4mm. Assuming that this was a problem with units, we imported the English cad file into Metric, then attempted to print that. It worked in a way, where that instead of being too small, it was scaled up a little (but not nearly as much as it was scaled down before). Which brings me to my question; Has anyone else had this problem? Are there any solutions?
Unread 08-01-2014, 09:30
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Re: 3D Printing and Inventor
I have been exporting drawings right out of Solidworks in the .stl format, opening them in the Makerware software and printing them directly with no problems (Makerbot Replicator 2). I wonder if your problem is with Inventor or Cube?
Have you tried the Cubify software they have donated in the virtual KOP...I found that it works very well too...at least that will isolate your problem. (I'm sure you can import your Inventor file into the Cube software too.)
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 08-01-2014, 09:38
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
In Inventor, when you Save As -> Save Copy As -> STL you need to also click the "Options" button to set the STL Units and Resolution. Even if the Inventor file is in inches, I believe STL units defaults to mm, which is probably what is messing you up.
Unread 08-01-2014, 12:47
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
WarrenV,
Let me know if Sanddrag's suggestion resolves the issue.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 09-01-2014, 15:24
FRC #1403
It worked! The only problem now is that it looks like a blob in some places, but it printed the correct size. Give and take, but we'll work with it. Thanks!
Unread 15-01-2014, 19:27
docdavies's Avatar
docdavies docdavies is offline
Doc Davies
FRC #0346 (RoboHawks)
docdavies is an unknown quantity at this point
Inventor will screw up some files like that. I find it depends on the shape. There was a point in time that I had to make in IP save in Solidworks and then pull into Makerware to fix. On our Mendelmax we then had to save Makerware file as a "fixed" .stl pull into Sliz3r and print.
So much fuss....
Unread 15-01-2014, 20:16
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Mesh lab is a free tool you can use to repair STL files, or Bing it into slic3r and it auto repairs it. It can then be exported again.
Unread 16-01-2014, 07:28
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
The 'Save As' in Inventor never worked properly for me - the reference plane was always messed up and the part would print on its side, even though the part was built 'up' from the XZ plane. However, I never noticed the 'Options' button that Sandrag pointed out.
What has worked for me in lieu of 'Save As':
File > Print > Send to 3D Print Service
It also allows for some tweaking, including scaling & converting to the units of the target 3D printer.
GitHub
Unread 22-01-2014, 09:49
Ideal_Nerd's Avatar
Ideal_Nerd Ideal_Nerd is offline
Team Caption
FRC #3591 (Wild Warbots)
Team Role: Driver
Ideal_Nerd has a spectacular aura aboutIdeal_Nerd has a spectacular aura about
we have the cube 2 and we save the file normally but in the cube software we found if you scale down your prints by 39.42% we get the right size.
