Go to Post Successful teams - in almost any aspect of life (i.e. not just robotics) - don't make excuses and assign blame when something goes wrong. They improvise. They adapt. They overcome. They correct the problem and move on. - dlavery [more]
Unread 08-01-2014, 10:50
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Question 2014 KOP Chassis OMNI wheel location
Dear CD,
If a team were considering replacing the KOP 4 inch wheels with OMNI's from Andy Mark, what would the advantages and disadvantages be for using either 2 OMNI wheels in the center only, or two wheels on either side only? Does either offer a major disadvantage?
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 08-01-2014, 10:53
Re: 2014 KOP Chassis OMNI wheel location
The new AM14U is a drop center chassis, so you are not gaining much by adding in omni wheels. I don't see a reason to change a standard drop center 6wd out for omni's in the corners, and definitely not in the center.
Why are you considering this? Do you plan to go with a long 4wd or 6wd?
Unread 08-01-2014, 10:57
marccenter's Avatar
The BOOM Done robot featured mechanum or swerve type wheels to enhance maneuverability. The addition of OMNI wheels is a step in the direction of better maneuverability without the full complexity of mechanum drive.
Marc Center
Unread 08-01-2014, 11:02
They were mecanum wheels.
Unread 08-01-2014, 11:14
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
In the short/wide configuration there may be an advantage to using omni, since there is no center drop. When I discovered that I became very concerned that three co-linear very grippy wheels will be difficult to turn effectively...as a result, we're going with the long config.
I'd love to hear impressions from the drive-train dynamics experts on this topic.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 08-01-2014, 11:24
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
A 6WD with drop center is already very good at turning in place, and still has fair traction for going forward and resisting a sideways push.
If you want to put some omni wheels into a 6WD, I wouldn't recommend putting them in the center. That would reduce your traction in both directions, and wouldn't really help much with turning.
If you really want to maximize your ability to turn in place, and are willing to sacrifice some traction, you could put the omnis in the four corners. The tradeoff doesn't seem worthwhile to me, but then I don't know your robot strategy.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Iaquinto.Joe's Avatar
Iaquinto.Joe Iaquinto.Joe is offline
RPI 2018
AKA: Joe Iaquinto
FRC #0308 (The Monsters)
Iaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the roughIaquinto.Joe is a jewel in the rough
Team BOOM Done didn't use the AM14U chassis. They state it in their release video.
4 year 2011 - 2014 FRC team 308 member, Lead Programmer - C++ / LabVIEW
3 year 2011, 2013, 2014 OCCRA member, Co-Captain OCCRA team 308
  • OCCRA Engineering Excellence - Waterford Kettering 2013
  • Innovation in Control - 2011
  • Quality award- Northville 2012
  • Engineering Excellence- Howell 2014
  • Innovation in Controls- Livonia 2014
