Go to Post Our behavior – both good and bad – is contagious. Set a good example, behave in a mature, reasoned, professional manner and we will find that others around us will too. - dlavery [more]
Unread 08-01-2014, 12:10
Re: How to make timed sequences in java?
Originally Posted by omalleyj View Post
Hard to say without looking in detail. You have the constant tests for setting and checking vs. the context switch to handle the thread.
Your "polling" code (a form of state machine as shown) runs once every 20ms yes? While you're waiting for the 2 seconds to elapse, you're doing one simple conditional jump every 20ms.
If CPU usage becomes a problem using this approach, there's probably something seriously wrong elsewhere in the code.
