| View Poll Results: CAN WE USE A N64 CONTROLLER TO CONTROL THE ROBOT???? | |||
| YES YOU CAN!!!! |
16 | 37.21% |
| NO YOU CANT!!! |
27 | 62.79% |
| Voters: 43. You may not vote on this poll | |||
[DOES ANYONE KNOW IF A N64 CONTROLLER IS ALLOWED TO BE USED TO CONTROL THE ROBOT?????
As long as you know how to wire it properly, then yes you can....
This doesn't belong in this forum, though. |
I don't think so........its not a standard (15 pin?) joystick that uses the standard joystick port (ie you can't use USB joysticks either).
I would ask FIRST to be sure. |
There is nothing in the rules that says you cant, but as Harrison said, ask FIRST |
And please, keep your questions calmer. All caps, bold, underline, emotions don't make for faster responses.
As long as you can wire it properly I can only assume that it will be allowed. |
you can, we've made our own custom controls the past 3 years |
#7
There is a big difference from making your own custom controls and modifying an off the shelf joystick/gamepad.
Look at the restricted parts list. It says that joysticks, etc must use a 15 pin interface. In my mind, this means that you may not use a modified n64 controller. Ask FIRST, though Edit: see this thread for clarification: http://jive.ilearning.com/thread.jsp...9&message=2383 |
#9
Yeah.. even better..
Use a old Nintendo, and put of OI in the shell of the system (Remove other components). Then use the super pad, or the standard controllers for controls. It would be awesome... I got the idea after seeing this guy turn his Nintendo into a computer: http://www.junkmachine.com/nintendo/...tutorial.shtml |
#10
the way all nintendo control devices send data is not in a form the OI can handle easily, a constant "tick" is sent through one wire to sync the controller circitry to the box, data is then transmitted in a pseudo-compressed binary stream over another cable, the box interpets that data and does what it needs to do. The OI can't really handle that without some decently complex electronic work, it would prolly be easier to make a custom board
even if you could sync with the controller and get the data, you still have more to do. When the box starts up, it recieves data telling it what the controller does. Look it up online, there is a lot of docs on the subject. The timing is the real problem. Ithought about doing this with something simpler, and i think the only controller that could easily synk with the OI, is old sega controllers (if i remember corectly, the master system and saturn controllers could work), they don't use the timing/stream type system, each wire is normally set to a button. I really don't know if it's allowed, but i dont particularly care, we have custom circutry. ![]() |
#11
You could always tear apart the controller and remove all the elcronics then replave the pots and sitches with your won, it would be legal and you'd get around nintendo's IO format.
#12
we had the idea of using a game cube controller this year, but our team had much more important things to worry about...like wiring the ROBOT!
Bad |
#13
Use the GameCube controller over the N64. It has two controll sticks over the N64's.
#14
This idea brings to mind another question: It WOULD be against the rules to use a Wavebird, right? ![]() |
#15
Mine team asked FIRST if we can use a controller from playstation and they said no because must video game controllers are not 15 pins
| How much planning goes into your robot? | Jnadke | General Forum | 41 | 29-01-2006 21:29 |
| serious problem found - robot controller resets when jarred! | KenWittlief | Electrical | 23 | 19-03-2003 13:30 |
| Can We Use A N64 Controller To Control Our Robot??? | pobots | Rules/Strategy | 1 | 11-02-2003 23:14 |
| RoboCon 1.01 (control robot from PC) | rbayer | Programming | 20 | 06-11-2002 21:30 |
| about how Drive Train push the robot... shouldn't the force accelerate the robot? | Ken Leung | Technical Discussion | 12 | 26-11-2001 09:39 |
