Go to Post Thanks GDC for opening a can of Chuck Norris Brain Hurt - Garrett.d.w [more]
Unread 08-01-2014, 16:44
Andrew Lawrence
Posts: n/a
Flow control?
In our prototyping tests we could not get cylinders to extend quickly enough to provide enough force to launch the ball very far, but we've seen videos of teams launching well over the truss using a single cylinder. While we don't have the most experience with pneumatics, we believe this is due to the lack of an adequate air flow rate to the cylinder. If you've successfully launched a ball with cylinders, what did you do to get enough air flow?
Unread 08-01-2014, 16:46
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Flow control?
How high would you define as a successful launch with just a piston? We've had okay results in that we made on that can move the ball a decent amount but it doesn't have the range we want.
1058 PVC Pirates 2016 - xxxx
Unread 08-01-2014, 16:49
Andrew Lawrence
Posts: n/a
Re: Flow control?
I'd say a successful launch is from about 3 feet off the ground over the truss from a few feet away. The videos I've seen are clearly powerful shots that span a decent distance (I'd link to them but they're on facebook), but my goal is to just be able to lightly lob the ball over the truss reliably. Our tests maybe move the ball a few feet, but not enough for shot that would make it over the truss.
Unread 08-01-2014, 17:00
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Re: Flow control?
I don't think you can use a flow control to step up the pressure to a cylinder. I've only ever used flow control valves to slow cylinders down. What cylinder are you using? What's the stroke length, diameter, and psi rating? You can use a higher psi and/or a smaller cylinder diameter to extend more quickly. If you have a regulator in place between your air tanks and solenoids you could tweak it until it's allowing a higher psi to flow to your cylinder (just make sure it can stand the higher pressure; some might not be rated to the full 120 psi we're allowed).
FIRST Team 1732- Hilltopper Robotics
Website, Facebook, Twitter, Instagram
Unread 08-01-2014, 17:04
Racer26 Racer26 is offline
Re: Flow control?
In 2008, 1075 came up with a pneumatically driven firing mechanism that involved 3x1.5" bore cylinders, fed from independent valves (switched together in software), that pulled a block and tackle pulley system to move a carriage along a rail (and into a hard stop at the top).
While not as simple as "punch ball with pneumatic cylinder", strictly speaking, it WAS firing the trackball using pneumatic power. IIRC there was also elastic power coming from the surgical tubing to assist the pneumatic cylinders in the "firing" direction (which the cylinders would then stretch to reload for the next shot).
Unread 08-01-2014, 17:29
Everett33's Avatar
Everett33 Everett33 is offline
AKA: Everett Owen
FRC #2145 (HAZMAT)
Everett33 is on a distinguished road
Re: Flow control?
The cylinders provide plenty of power to move the ball, but to get the speed you are looking for you might have to add springs or surgical tubing to your mechanism to get the ball over the truss.
I walk the pits of FIM and take cool robot photos.
•Lead Driver 2009-2013 •Mechanical Mentor 2014-2015
•Record of 6-2
Unread 08-01-2014, 17:56
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
Re: Flow control?
Wait, you can't have a cylinder at 120 PSI, can you? Doesn't the working side have to be 60 PSI?
Also, they eliminated rules about valve flow rate. The only remaining rule is that the limit is 1/8 inch NPT diameter. In my understanding, you can get a new solenoid valve that should make a cylinder extend faster. Thats my understanding anyway.
Unread 08-01-2014, 17:58
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Flow control?
There are a few things to try to get speed out of a cylinder.
#1 Get a solenoid with the highest CV you can find.
#2 Keep your tubing runs as short as possible (even go as far as plumbing the solenoid right to the cylinder.
#3 Remove the exhaust port on the cylinder and use spring return.
#4 Use low side storage tanks as close to the solenoid as possible.
#5 Replace a large diameter cylinder with several smaller diameter cylinders each with their own solenoid.
#6 use a lever to speed up the action, kind of like gearing up a motor.
Anything to get that air going as fast as possible into that cylinder.
Unread 08-01-2014, 18:09
Ernst's Avatar
Ernst
AKA: Ernst
Re: Flow control?
Oops, yup. You got me.
4.10.9 R82
“Working” air pressure on the ROBOT must be no greater than 60 psi and must be provided through one primary
adjustable, relieving, pressure regulator.
Unread 08-01-2014, 18:21
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Flow control?
To this end, if you wanted to be really extra nutty, get a solenoid with 1/8" NPT ports, with the highest CV you can find, plumb the output directly to the cylinder with brass fittings or pipe nipples (I think pipe nipples might count as fittings?). Also plump a large low side reservoir directly to the input of the solenoid. Yes it'd be big and bulky, but it'd also get you the fastest actuation possible.
Unread 10-01-2014, 11:23
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: Flow control?
Indysam
Can you explain this to me.
How does this work and what does it do?
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 10-01-2014, 11:58
nickcvet89 nickcvet89 is offline
FRC #1228 (RoboTribe)
nickcvet89 will become famous soon enough
Send a message via AIM to nickcvet89
Re: Flow control?
If you want pistons to extend or retract faster, remove a fitting from either your inlet or outlet on the cylinder. Essentially you will only hook one side of the cylinder with air, while the other side will have an open port with no fitting. Try it and let me know how it goes. We have had great success with it.
Unread 10-01-2014, 12:07
Bruceb's Avatar
Re: Flow control?
that much I understood. What I dont understand is
Can you explain that?
Unread 10-01-2014, 12:15
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
Re: Flow control?
The regulator and hose in proportion to its length create restrictions. So if you've got a low pressure storage tank then you eliminate the regulator's restrictions and if you place it close to the valve as possible and the valve as close as possible to the cylinder you minimize the restriction caused by the hose.
Unread 10-01-2014, 12:28
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
Re: Flow control?
One thing that you can do to help the extension speed of the piston is have 2 cylinders and some form of latch. The large cylinder you will punch the ball with is set up so that the latch will prevent it from extending until the smaller cylinder releases the latch. This way you can run air through the solenoid into the large cylinder to "pre-pressurize" it then release the latch. With the air already in the cylinder and not having to flow through the solenoid it should extend faster because it is not limited by the flow through the solenoid.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
