Go to Post I remember as a kid thinking how high a team number like 834 was. - Dancin103 [more]
Unread 08-01-2014, 17:37
LOHS3868 LOHS3868 is offline
FRC #3868
LOHS3868 is an unknown quantity at this point
CIM Motor Neutral Gear Setting?
Is there any way to set a CIM motor into a neutral style gear? We're trying to put our motor into a free spin to release tension for a catapult.
We're also considering the Sonic Shifter from Andy Mark
http://www.andymark.com/product-p/am-sonicoptions.htm
There are two gear options - a low and high. We were wondering if we could remove one of the gears for a free spin function.
Also, we're still considering numerous catapult ideas and wanting any input that you may have - share your ideas!
- Team 3868
Unread 08-01-2014, 18:02
AlecS AlecS is offline
FRC #1323 (Madtown Robotics)
AlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond repute
Re: CIM Motor Neutral Gear Setting?
If you're looking into a dog shifting setup, the WCP PTO add on kit includes the shifting hardware to shift into a gear, or a sprocket/belt. It was designed for mechanisms requiring shifting/releasing, it interfaces into the PTO, or you can put it into a custom gearbox. The WCP DOG is made of stronger 4140 Steel, and is thicker for more strength, and allows the use of a roll pin to prevent shearing the dog screw.
Links
WCP DOG 217-3636
Hopefully this helps
Alec S.
Engineer - Sales Representative, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 08-01-2014, 18:42
Are you planning to hold the tension by stalling the motor?
Unread 12-01-2014, 17:30
ahartnet's Avatar
ahartnet ahartnet is offline
AKA: Andrew Hartnett
FRC #5414 (Pearadox)
ahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond reputeahartnet has a reputation beyond repute
Check out this video: http://www.youtube.com/watch?v=SWO9OE8JZZk
They showed how they used a rachet to prevent the motor from stalling and a dog shifter+pneumatics to release the motor from the axel to allow for freely spinning (for a catapult).
Lots of things I really like about the design of this robot shooter.
