Go to Post FIRST's awesomeness cannot be described in numbers. - Shinglei [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 08-01-2014, 08:52
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Ball dimensional variability
We just wanted to pass on a bit of news.
Last night, as we began prototyping shooting and pickup mechanisms, we realized that we had been accepting the specs and CD for the dimensions of the ball. As a double check, we actually measured our ball. We did this by placing it against a wall, with a vertical surface touching the other side of the ball, measuring its diameter caliper style.
The first thing we noticed is that after 4 days the ball is no longer round. Rather, it is "lobed". Rotating the ball to measure the max diameter across the lobes gives a max dimension of 25.75", a good deal larger than the ~24" specified in the game manual.
We wanted to get this out there to make teams aware that if they design mechanisms for a 24" diameter ball, the actual balls may become jammed.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 08-01-2014, 09:11
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Re: Ball dimensional variability
Todd,
How much of wear (if any) does the ball have, and how much of use has it gone through? We'll have to check our own ball's dimension and see if it's matching the change in shape that you seem to be getting. Perhaps the colder temperature is affecting the air pressure of your ball?
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 08-01-2014, 09:15
wilsonmw04's Avatar
wilsonmw04 wilsonmw04 is online now
Coach
FRC #1086 (Blue Cheese)
Originally Posted by Anupam Goli View Post
Todd,
If the temp were the case, it would make it smaller not larger.
My guess is that it has more to do with the cover than the ball. Variability is going to be something we are going to have to deal with. 1.5" is not that big of a concern. It's better than the basketballs in Rebound Rumble.
Unread 08-01-2014, 09:31
ToddF's Avatar
mechanical engineer
AKA: Todd Ferrante
Very little wear, and very little use. We've tossed it around and bounced it by hand a bit. We also took it outside to test some crude shooter schemes (see-saw using a 2x4). After a few minutes in the cold (~20 deg F), it had shrunk noticeably, with the cover becoming wrinkled. Bringing it back inside restored the ball to size.
Todd F.
Photo gallery
video channel
Triple Helix mobile
Unread 08-01-2014, 09:35
Rishabhgadi's Avatar
Rishabhgadi Rishabhgadi is offline
Alumni, 1255 mentor
FRC #1255 (Blarglefish)
Rishabhgadi is an unknown quantity at this point
After the experiance with the Basketballs I beleive everyone is prepared for this.
Unread 08-01-2014, 09:40
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Except for all the rookies from 2013 and 2014, whether it be new teams, or new students/mentors.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 08-01-2014, 09:46
AKA: noops
Whoops, got it backwards. Sorry about that!
I think wilsonmw04 is correct in suspecting that the change in ball shape may be due to the cover of the ball and the shrinking/expanding it went through. As the ball's volume changes, the cover gets more worn and stretched.
Unread 08-01-2014, 11:51
RaxusPrime's Avatar
RaxusPrime RaxusPrime is offline
Driver and Programming Captain
AKA: Brennen Martin
FRC #3883 (DataBits)
RaxusPrime is on a distinguished road
Do you think it might be a major factor during competition then?
Unread 08-01-2014, 13:03
wilsonmw04's Avatar
Coach
I don't think so, unless you are designing something that needs to be snug to the ball. Since is gives a bit when force is applied, I don't see it being an issue.
Unread 08-01-2014, 18:23
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
Do we happen to have a mass on this ball? Can't be much more than a pound and a half, right?
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
Unread 08-01-2014, 18:28
M.O'Reilly M.O'Reilly is offline
AKA: Mike O.
FRC #4637 (BambieBotz)
M.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of lightM.O'Reilly is a glorious beacon of light
I am surprised that your ball is deformed, and I surmise it was manufactured that way. The only way I could imagine that the ball would get deformed is from someone sitting on it. Again, normal exercise balls are meant to bear weight, so my guess is it was manufactured this way, and we can expect to have to deal with heterogeneity at competitions.
Unread 08-01-2014, 18:48
Henrique Schmit's Avatar
Henrique Schmit Henrique Schmit is offline
FRC #1156 (Under Control)
Team Role: CAD
Henrique Schmit is an unknown quantity at this point
I've heard that one of our mentors calculated the ball's mass as more than 1kg, i think it was 1,3kg.
Unread 08-01-2014, 18:56
kws4000's Avatar
AKA: Krazy Karl
So that works out to 2.86 pounds. Thanks!
Mentoring:
Unread 08-01-2014, 19:01
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Does this include the mass of the air when filled?
Unread 08-01-2014, 19:45
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Our ball measured 25in +/- 3 in as measured over several different diameters.
The fact that yours is 25.75in OD is somewhat disconcerting...
