Go to Post Logic has no place here whatsoever. - ThamiorLianodel [more]
  #46   Spotlight this post!
Unread 08-01-2014, 12:43
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
Re: Mecanum wheels
Originally Posted by TheMadCADer View Post
Hitting a moving target is added complexity you don't need. I'd pick a catcher that has no wheels at all before I'd pick one with mecanums.
So ... you'd rely on the 100% accuracy of the throwing robot, rather than provide some flexibility by allowing the catcher to adjust?
Put another way, if the ball is a mere 6" off target, you'd rather have the ball bounce off you (and then have to go chase it) than see a robot with the ability to take a half step to the right?
"It's NOT Just A Robot Thing!"
  #47   Spotlight this post!
Unread 08-01-2014, 12:58
TheMadCADer TheMadCADer is offline
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Re: Mecanum wheels
Based on initial ball launching prototypes, yes I would.
My point is that the ball will never be anywhere close to 6" from being caught, it will be much farther away and completely un-catchable because a mecanum robot can not hold field position. If your catching robot uses mecanum wheels, pushing it out of the way will be a common and effective defensive strategy. In a game like this where field position is everything, a mecanum robot is at an extreme disadvantage.
The only role I can see a mecanum robot playing effectively is a robot that cycles the ball by itself with no assists. As soon as it tries to play a role where it has to stop and wait for its alliance to do something it would lose its field position and ability to add assist points.
  #48   Spotlight this post!
Unread 08-01-2014, 13:15
Re: Mecanum wheels
... a mecanum robot can not hold field position. If your catching robot uses mecanum wheels, pushing it out of the way will be a common and effective defensive strategy. In a game like this where field position is everything, a mecanum robot is at an extreme disadvantage.
Does the same argument apply to giving a healthy bump to the lighter corner of a 6WD drop-center bot?
  #49   Spotlight this post!
Unread 08-01-2014, 15:54
Re: Mecanum wheels
To a degree. It requires a more directed bump/push than defending a mecanum robot, and a 6/8 wheel drive train can better resist the imparted turning motion by turning against it, allowing you to hold a stalemate. Trying to drive a mecanum robot that is already slipping is an exercise in futility. The bump also causes rotation more than sliding, which would keep general field position close to static. In this case a good catcher would be orientation-agnostic.
Having a robot that can be pushed in any way is disadvantageous to being a good target for catching, so I'd say the best pure catcher is a robot without wheels. However, making the trade-off of allowing some pushing in exchange for the ability to move and complete other tasks could be a successful strategy. Toggling between a drivetrain and a traction device would give the "best of both worlds" at the expense of complexity (independent swerve being another solution, albeit even more complex).
  #50   Spotlight this post!
Unread 08-01-2014, 16:04
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Re: Mecanum wheels
Designing to be defended against is a really good way to put a ton of work that may or may not see a benefit in competition.
Remember 2006, when 25 had a robot that was solely human fed, and basically shot from the floor? And went undefeated right up through division elimination rounds?
Ultimately the benefit of mecanum ends up coming down to what your game strategy is. If it's to be a flexible assist bot, it may very well be worth it-- if it's being a thrower bot, it very well may not be. Ultimately it's all just speculation until we get to competition regardless. Just like any other year, there will be successful 6WD robots and successful mecanum robots.
The team makes the tools it uses worthwhile, not the other way around.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
  #51   Spotlight this post!
Unread 08-01-2014, 16:19
Re: Mecanum wheels
...a 6/8 wheel drive train can better resist the imparted turning motion by turning against it, allowing you to hold a stalemate.
I wonder if anyone has ever actually conducted such a test under controlled conditions. The mec bot would have a larger effective wheelbase than 6W drop center. And mec wheels (at least the affordable ones commonly used for FRC) are somewhat harder to push sideways than fwd/rev. Might make an interesting off-season science project to verify this claim or lay it to rest.
  #52   Spotlight this post!
Unread 08-01-2014, 16:33
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: Mecanum wheels
Originally Posted by Qcom View Post
Question: You mentioned the Vex Mechanums cracking in an earlier post. Where did they break, and was the break catestrophic enough to warrant immediate disabling of robot movement (i.e. could the robot finish a match if this occured)?
Someone mentioned that they had a VEXpro mecanum wheel crack, but did not provide any additional information. We've done a lot of testing here and not seen any durability issues. We've also not heard very many complaints from users about Mecanum wheels breaking.
We're very happy with how that design turned out, and are confident in the durability, especially in a game with a flat field like Aerial Assist.
If you jump a robot off a loading dock, will the wheels crack? Yes: Based on our testing... not until the 3rd jump.
If you slam the wheels into a wall with a rolling robot, will they crack? Not in our testing.
I'm confident that VEXpro Mecanum Wheels will stand-up to normal wear and tear during an FRC season. If a wheel breaks, it is likely that the wheel wasn't damaged due to extended match play, but instead the robot was dropped when being loaded into a mini-van.
Also, I hope it goes without saying for VEX products at this point:
If you have a problem or break, please contact our tech support folks so they can help make it right. prosupport@vex.com
I'm especially excited to see teams using our new 4" Mecanum Wheels. This game lends itself perfectly to small wheels, and I believe there are some strategies which would benefit from holonomic motion.
-John
  #53   Spotlight this post!
Unread 08-01-2014, 16:43
SMHS SMHS is offline
Jay Maine
AKA: Dan Lemieux
None #3930
SMHS is an unknown quantity at this point
Re: Mecanum wheels
Is there any information on mecanums wheels and drivetrains? Live Axle vs Dead Axle?
I have never use them and am looking for information. Transmission? Does and one have some good information to share. Thanks
  #54   Spotlight this post!
Unread 08-01-2014, 16:47
Re: Mecanum wheels
Where have you been looking?
  #55   Spotlight this post!
Unread 08-01-2014, 16:56
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Re: Mecanum wheels
Is there any information on mecanums wheels and drivetrains? ...
Sure, there's lots of info. See that search link at the top of this page? Click it, enter "mecanum", and you'll find lots.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
  #56   Spotlight this post!
Unread 08-01-2014, 18:33
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
Re: Mecanum wheels
Apologies to JesseK and bEdhEd. I was not attempting to say either of you said there was power loss for mecanum moving forward/backward. I was not trying to counter what either of you said, but using your correct statements as an example of the types that are very commonly misinterpreted.
my post was attempting to be pro-active about a future reader's misinterpretation, and was instead itself misinterpreted. I think there is a word for that (other than failure). I guess we can agree that I clearly didn't say it very well.
  #57   Spotlight this post!
Unread 08-01-2014, 18:38
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Re: Mecanum wheels
Ah, I understand what you were trying to do. I guess your motive just wasn't clear enough for us to get. Part of it may have been our bad too.
As for your apology, team bEdhEd graciously accepts!
  #58   Spotlight this post!
Unread 08-01-2014, 19:37
Qcom's Avatar
Qcom Qcom is offline
Gearhead
AKA: Quentin
FRC #2996 (Cougars Gone Wired)
Qcom is on a distinguished road
Re: Mecanum wheels
-John
Wow! I was not expecting a VEX engineer to reply. Thank you, I think that may seal the deal.
"The systems... They DON'T INTEGRATE!"
  #59   Spotlight this post!
Unread 08-01-2014, 23:53
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
Re: Mecanum wheels
So Mecanum vs 6WD and all things being equal I understand most of the pros and cons.
But if you look at the Robot in 3 Days team Boom Done they have 8 motors on their drivetrain - 4 cim and 4 minicim. What if instead of having a straight gear reduction, a team were to use a direct drive shifting transmission such as the Vex Pro ball shifter on each Mecanum wheel with a Cim and Mini-Cim as the input to each wheel? And you took that against a 6WD drivetrain with the three CIM Vex Pro Shifting transmission per side?
Does that muddy the water a bit?
  #60   Spotlight this post!
Unread 09-01-2014, 00:30
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: Mecanum wheels
What would lead you to believe that it would muddy the water? Can you provide reasons why, in your estimation, the mecanum drive implementation you're suggesting here would fare better against the 6WD robot you're describing than a more typical mecanum drive?
Do the math and you'll have your answer. This stuff is pretty cut and dry.
--Madison--
...down at the Ozdust!
