Go to Post If you thought two alliances racing to tip the bridge in auto was exciting, wait until they play autonomous chicken on the center line. :D - Alpha Beta [more]
Unread 08-01-2014, 18:24
DampRobot's Avatar
Physics Major
AKA: Roger Romani
7/16-28 Bolt or Threaded Rod
Does anyone have a good source for 7/16-28 bolts or threaded rod? I've looked at MSC Direct and McMaster, and they don't appear to have any. We need one to go into a very specific mechanism which only mounts with a bolt of that size tapped into the end.
-Plutarch
Unread 08-01-2014, 18:27
AdamHeard's Avatar
Lead Mentor
Re: 7/16-28 Bolt or Threaded Rod
Do you have a manual lathe?
Wouldn't be too crazy to just cut one.
Unread 08-01-2014, 18:50
DampRobot's Avatar
Physics Major
AKA: Roger Romani
We do... Although no one really seems to know how to use the threading setup.
-Plutarch
Unread 08-01-2014, 19:05
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
You might check Fastenal.
2016-17 events: 10000 Lakes Regional, Northern Lights Regional, FTC Burnsville Qualifying Tournament
2011 - present · FRC 3081 Kennedy RoboEagles mentor
2013 - present · event volunteer at 10000 Lakes Regional, Northern Lights Regional, North Star Regional, Lake Superior Regional, Minnesota State Tournament, PNW District 4 Glacier Peak, MN FTC, CMP
http://twitter.com/MrRoboSteve · www.linkedin.com/in/speterson
Unread 08-01-2014, 19:31
DampRobot's Avatar
Physics Major
AKA: Roger Romani
No juice.
-Plutarch
Unread 08-01-2014, 19:41
Chexposito's Avatar
Chexposito Chexposito is offline
AKA: Expo
FRC #1730
Chexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of lightChexposito is a glorious beacon of light
Originally Posted by DampRobot View Post
No juice.
Try calling them, if you looked on their website. Sometimes they have it somewhere, just not on their site.
Source: Worked in a factory, learned first hand calling is better.
Unread 08-01-2014, 20:25
amainville amainville is offline
FRC #4000
amainville is an unknown quantity at this point
Check out youtube for videos of thread cutting using your brand of lathe. Thread cutting is relatively easy once you figure out the basic operations of your lathe.
Unread 08-01-2014, 21:47
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Could you just buy the die and cut threads on a rod? This thread size is fairly common for panel mounted electrical switches.
Richard Wallace
since 2003
Unread 08-01-2014, 21:52
T^2 T^2 is offline
FRC #5499
I'll second this. I've had success with manually setting a die in a lathe tailstock chuck and turning the main chuck (with the rod in it) by hand.
Unread 08-01-2014, 22:09
DonRotolo's Avatar
Back to humble
FRC #0832
I'll third it.
Cutting threads on any length over a few inches on very thin rod with a lathe is very tricky, and requires a follower rest and the right tooling. And, even then, without experience, the threads won't be great.
A die will produce excellent threads of the right size on significant lengths of rod at a very low expense and relatively fast speed.
Remember, you don't need the whole length threaded, do you? Just the end...
Buy the die. Trust me.
Unread 08-01-2014, 22:22
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
Amazon lists the die for about 10$. If speed is important take the threaded barrel of a switch and solder it on a rod or bolt. Just make sure you have the treads in the correct spot when tight.
KF6UZX
Unread 09-01-2014, 01:50
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Call Tony at Olander in Sunnyvale
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 09-01-2014, 12:34
FRC #0192 (GRT)
I second this suggestion.
KF6UZX
