Go to Post It kicked off today, and we already have 10 pages of posts!?!?! - ShotgunNinja [more]
Thread Tools Rating: Thread Rating: 20 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 08-01-2014, 16:37
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Re: Thoughts on the new AM14U 2014 KOP Drive train?
Originally Posted by Shu View Post
I'm sorry but we haven't got a chance to look at this in CAD yet but has anyone looked at making a square chassis by cutting ~2" off each end. I am sure this will require new belts but are the front/rear axle holes available for this. This keeps the front and rear wheebase the same.
Yes - front and rear axle holes are available for removing two inches on each side (front and back). This would result in the closest six wheel "long" configuration available without drilling new axle holes, and would give you a center drop. We examined this last night, and decided to remove one inch from each, thus using the "middle" of the three available axle holes, and ending up with a slightly longer that square bot.
Also worth noting: The instructions produce a bot that is still 2 inches under the maximum perimeter size (either configuration)
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
  #32   Spotlight this post!
Unread 08-01-2014, 23:42
jblay's Avatar
jblay jblay is online now
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Has anyone put together a CAD file of the square version of the drive? I feel like that could be useful to a lot of people that are thinking about the square option...like 694 perhaps.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
  #33   Spotlight this post!
Unread 09-01-2014, 00:07
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
My team choose to build the long configuration because we determined that the wide base would be very tipsy, especially when driving defense, and the long chasis would be better for defense because its longer and the way we play defense. One thing about the long base is that you can not directly feed because the frame is 23 inches wide and the ball is 24, but with our strategy it worked out perfect, we are planning and doing basically the same robot as team O-RYON did for their ri3d.
  #34   Spotlight this post!
Unread 09-01-2014, 00:47
Best Available Data
FRC #1778 (Chill Out!)
We haven't quite got it in CAD yet, but we did already build it. You just use the long belts on one side, the short belts on the other, cut off the part of the rail that sticks out, and cut the cross-braces and long churros to what you desire. We can't count and ended up at 27.5x27 though. We used a bandsaw to cut down the rails, and our manual mill to cut out one notch where the edge rail and back rail intersect, but you could use a bandsaw for that too. Went together lickety split, hopefully driving it around tomorrow.
Unfortunately I don't have a good unobscured picture of it, this is the best I can do.
  #35   Spotlight this post!
Unread 09-01-2014, 01:05
AndreaV AndreaV is offline
FRC #1360
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
This year at the 2nd annual quick build that 610 hosted a dozen AM14U chassis were up and running by 7pm on the Saturday of kickoff. Last year we had only 1, with a vast majority of them ending up at the electronics and programming stage.
The frame is LIGHT. I am a bit envious. the churro is a dream to work with, the front and back rails are super rigid. Having used direct drive last year on our custom frame, I can really appreciate what you guys have done with the center wheel/gearbox. The flanges at the bottom for the electrical panel makes drop in belly pans really easy. The belts center to center was BEAUTIFUL I drooled.
A few teams assembled it incorrectly, and it was surprisingly easy to disassemble and flip the parts around. even with all the churro contact points, I can see wheel changes and drive train maintenance being a breeze. Oh wait, belts, what maintenance?
Now the bad:
I really really really REALLY wish the inside plate (as in the ones the gearbox is mounted to) had a flange bent on the top to match the one on the outside, making the inner and outer rails the same height.. this would allow upper structure to be easily mounted across the top.
One of the rookie teams put some thin wood along the top as a sleek cover. Unfortunately, with a 1/4 wood electrical panel, the cover was right over top the victor fan. this caused them to pop a mosfet on the victor. this is not at all the fault of the chassis, they learned their lesson, but i could imagine other teams having a similar experience. with a flange on the inside this would be impossible as the fan would run into the cover/structure. The unbent flange lends itself to wood very well, but it makes attaching box tubing significantly more difficult.
So in closing really my main complaint is the lack of flanges all around. everything else is leaps and bounds better to the C-base of yesteryear. Lets never look back, EVER.
Last edited by AndreaV : 09-01-2014 at 01:13. Reason: forgot super spiffy direct drive
  #36   Spotlight this post!
Unread 09-01-2014, 03:03
brianbond's Avatar
brianbond brianbond is offline
Head Coach
AKA: Brian
FRC #5102 (The Underbots)
brianbond has a spectacular aura aboutbrianbond has a spectacular aura about
We decided to go with the Versa Chassis for our rookie year this year. We built the Kit Bot also just for fun as some of our students already have experience in FIRST. It seems to be a solid bot from what I can see. The only thing I would say about the versa chassis is you need to Mill the slots and I am not sure if you have access to a Milling Machine being your first year and I have not seen any posts about that. We have CNC access and that is how we are milling our slots. If you have that access, or even a manual mill with some experience, I would say go for it. Keep us all updated as to what you decide!
  #37   Spotlight this post!
Unread 09-01-2014, 03:38
AlecS AlecS is offline
FRC #1323 (Madtown Robotics)
AlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond repute
If you are using the VersaBlocks, no machining is required. We recommend drilling a 1.25"-1.5" hole with a hole saw in the tubing. All of the location and strength is done with the VersaBlock, the hole in the tube is just clearance. During Build Blitz, Team Copioli used a 1.25" omni bit to drill the holes, this worked excellent.
Alec S.
Engineer - Sales Representative, WestCoast Products || Twitter
MadTown Robotics Team 1323
  #38   Spotlight this post!
Unread 09-01-2014, 05:44
TD78 TD78 is offline
AKA: Tom Dolan
FRC #0078 (AIR Strike)
TD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant futureTD78 has a brilliant future
How is the front-to-back rock in the chassis?
FRC78: 2010-Present
FRC121: 2002-2009
  #39   Spotlight this post!
Unread 09-01-2014, 16:32
TerryS's Avatar
TerryS TerryS is offline
FRC #2445 (RoboKap)
TerryS is an unknown quantity at this point
I called Andy Mark this morning. If you want to make a square configuration by cutting two inches off of each end of the side plates and placing the wheels into the pre-drilled axle holes two inches in from the long configuration holes they recommend buying the 160T, am-2266 belt. This will give you equal wheel spacing.
Andy Mark hasn't tested this configuration yet, but they plan to soon as they've heard that a lot of teams want to be square this year.
"Genius is 1% inspiration, 99% perspiration"~Thomas Alva Edison
2016 Hawaii Regional Winners
  #40   Spotlight this post!
Unread 09-01-2014, 17:10
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
28", 4" vex wheels, sprockets, and Ball Shifters:
  #41   Spotlight this post!
Unread 09-01-2014, 23:33
Best Available Data
Not much. Guess I may have made a fool of myself assuming 1/2 of what was there in the long config would be enough. Software team spent all of today battling gremlins, so no report as to how it actually drives yet. Trying to turn it by hand on the carpet, seemed to me like there was quite a lot of scrub. May end up as an opportunity for the kids to get better at assembling and disassembling the AM14U.
  #42   Spotlight this post!
Unread 09-01-2014, 23:57
seanrobots's Avatar
seanrobots seanrobots is offline
FRC #2489
seanrobots is a splendid one to beholdseanrobots is a splendid one to beholdseanrobots is a splendid one to beholdseanrobots is a splendid one to beholdseanrobots is a splendid one to beholdseanrobots is a splendid one to beholdseanrobots is a splendid one to beholdseanrobots is a splendid one to behold
We like the versatility of it
  #43   Spotlight this post!
Unread 10-01-2014, 08:59
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
All,
We here at AndyMark have been following your discussions about the AM14U chassis. We wanted to share a quick video of you demonstrating the AM14U in both long and wide configurations, showing their maneuverability under weight loads simulating a fully loaded robot, on carpet. The video is here.
Enjoy, and keep the feedback coming!
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
  #44   Spotlight this post!
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
So far I think its a very decent chassis and for our previous three years I could see us using it with a few modifications. This year we are still up in the air as to what we should do.
One portion I'm not a huge fan of is modifying the kitbot to more square and even wide configurations. It is pretty straightforward to do but making several cuts on each side rail and re-drilling several holes isn't something I'm super excited about. There are a few other issues that I'm not a huge fan of like mounting the gearboxes we want to use and same for the wheels we want. Its all possible with the AM14U just some areas require more machining work and others involve using more parts whereas I would prefer each wheel/axle be identical for fewer parts and increased reliability.
I think we will opt to have our own 1/8in. side plates CNCed to tailor to what we want along with moving from belts to chains. Plus several other changes but the DT as a whole is still in design mode.
Overall I think its a great chassis but at least for our team we feel it is harder to build/modify to our liking compared to the C-Channel systems from previous seasons.
1058 PVC Pirates 2016 - xxxx
  #45   Spotlight this post!
Unread 10-01-2014, 11:13
jeremylee's Avatar
jeremylee jeremylee is online now
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
If we had seen both the kit and VersaChassis before signing up for the kit, we'd maybe gone the VersaChassis route. However, AM14U is growing on us as we work with it and we will likely use it for this year.
I agree about making it easier to change sizes beyond long and wide. I imagine an "upgrade" available with some different belt lengths for some additional sizes from Andymark wouldn't be too hard.
I also feel a 2nd 500EX hub on each size is a good upgrade is you are going 2 speed for strength.
One other concern for us is the difficulty replacing the center wheel. Looks like the best way would be to pull the side off, but that would require a lot of work at a regional. Replacing the end wheels shouldn't be too hard. 8 wheel drive option gets around this in long config.
