Go to Post Sadly this bot uses better punctuation and capitalization than many on this site. - Andrew Schreiber [more]
Unread 08-01-2014, 22:05
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
Keypad instead of joystick?
Hello all!
I've been thinking about using a keypad instead of a joystick for our secondary driver, as he normally has a lot of mechanisms to keep track of and hardly ever seems to use the stick part of the joystick.
My question is thus: Does anyone have experience programming third party keypads? This may sound crazy noob, but can you honestly just plug up some logitech keypad and all the functions are the same (GetRawButton, etc.,) or are there other libraries that are going to have to be downloaded, and if so do you guys have any recommendations for good/easy to program keypads?
Thanks!
Unread 08-01-2014, 23:47
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Keypad instead of joystick?
You could use an IO module to build a custom keypad (or interface to the raw input from an existing keypad).
In your code you would treat it just like a joystick, but you can physically configure the buttons any way you want to.
Unread 09-01-2014, 07:30
AKA: Michael Shires
FRC #0384 (Sparky)
whoa, thats awesome :O I'd never seen that before! thanks so much!
Unread 09-01-2014, 07:47
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Sparky, this is something I've dealt with in the past, starting with a PS2 Controller and eventually the XBox controller. In practice, you can use getRawButton (and getRawAxis) to slowly figure out what is what on the pad. Either output it directly to the DS User Messages or put it to the dashboard to make it really easy. I think you'd know, but just for reference, make sure you don't have any commands tied to the buttons/axes you are trying to discover and understand!
If you really need to get it done and have no time for a handbuilt joy pad, this is a solution.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 09-01-2014, 08:07
AKA: Michael Shires
FRC #0384 (Sparky)
yeah that would be pretty bad! Well that was why i was considering this now, so that we'd have all build season and the end of february and early march cause we're a week 4. I'd never heard of a custom keypad, that sounds like a really neat idea. that CCI control looks sweet.
Unread 09-01-2014, 10:20
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
The TI LaunchPad in FIRST Choice can also be used as an input module. After loading some new firmware, you can use the LaunchPad alone or with the Breakout BoosterPack (available very soon) as a set of two plug-n-play gamepads. Each gamepad has 11 digital and 4 analog inputs (22 and 8 in total).
Check out this link for more information: Using the Stellaris or Tiva LaunchPad in the FIRST Robotics Competition
I also have a CD thread that will be updated once the BoosterPack is ready to order.
-David
Unread 09-01-2014, 14:16
There's a new tool for doing this on the driver station. See http://wpilib.screenstepslive.com/s/...3053-joysticks and scroll down to Determining Joystick Mapping
Unread 09-01-2014, 16:29
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
Joe - thanks for pointed that tool out.
Brian
Brian K
Team 1225 Robotics Mentor
